425f and 413h
LanternGnome
425f and 413h
Post by LanternGnome »
Does anyone know if these two tanks can be swapped using a different generator ?
425f and 413h
And what generator would you be putting in which tank?
LanternGnome
425f and 413h
413h into 425f tank
425f and 413h
Sorry Carmine that I haven't responded yet. I am not sure.
If you have the 413 gen and 425 gen lay them on a table next to each other and check the length. If the thread length is the same, and diameter is close, I'd try it. My guess is the 425 gen is narrower and maybe shorter. Remember the pricker rod has to thread into the valve as well.
LanternGnome
425f and 413h
Thanks!
hurricaner
425f and 413h
Post by hurricaner »
No, the 413H is a longer generator. Edit: should have read the whole thread. The 413h tank is not interchangeable with a 425 tank.
Sam
