So in a recent post another member mentioned using a pricker rod from a 220 in a 220A generator.  I tried this recently and could not get the 220 pricker wire to go through the 200A tip. Which makes some sense because the 200A tip orifice is .007" and the 220 is .008" (see table below - data was extracted from Matt Reids GREAT table).
So what if you put the V gas tip on the 200A generator. The pricker should work.  BUT, would the extra 0.001" orifice over-drive the mantle on the 200A?
mgmlvks
Cross section area from 0.007 to 0.008 increases by 30%
Best answer is "try and see"
diameterradiusradius E2piarea sq inchesincrease
0.007   0.0035000   0.0000123    3.1415927                           0.0000385
0.008   0.0040000   0.0000160    3.1415927                           0.000050331%
Francis Bacon
It is enough of a difference to make CF and kero run at an optimum output. Kero would need less fuel and more air to give us roughly the same candle power from the same gas (CF) lantern.
Are you saying that the 200A with a 220 V orifice could run kero?  That would be a gas (ha! pun intended).
I think i will try it with CF first.
philbotha
Phredd wrote:
No, just the opposite: A 220 will run on kero with a 200A gas tip.
-Phil
Favourites: 238A B/41, 238B 6/50, Petromax 816 lamp, Petromax 827 lantern, Primus 1020, 1060, 1001, 995 lamp, Radius 108, Optimus 1200, 246B 5/41 241A 5/52, Veritas Gloria lamp 1922, Gloria Oxo-Gas 1913 The Evening Star 1924 lamp, The Evening Star 1922 lantern, Sunflame 104(US), Sunflame 106(UK), Bialaddin 300X,TL10, BR49, PL53,
Stoves: Coleman 425B, Primus 96, 523, 535, Optimus 111, Radius 43, Speedmaster 500 D/38
275 Appreciation Syndicate Member #0181 The only one in Africa?
Coleman Blue's 243's. registration #133 (the fourth known 243K)
salukispeed
With tips from the folks here I have a 220E running on a "6" tip from a 200A  on Kero. and it works well. Mine is not a retina burner but lights the yard pretty good. I also ordered a 201 preheat cup from OCP that I am going to try as soon as it gets here. But with a good preheat from a small butane torch it lights nicely.
ICCC 1868
Perfection appreciation #10
Milspec 65252
salukispeed
With this talk of small diameter holes is there a tapered pin or stepped pin available to accurately measure these. ( By Eye does not work ) and As I get older it does not work even more!!
ICCC 1868
Milspec 65252
Thank you for catching that Phil. Have a good new year.
Bob,
I've found small diameter measuring tools at a welding shop as 'gas re-sizing" kits or something for NG and LPG orifices. As I recall they didn't go below .0008 the last time I looked so I passed. I suppose a search on the internet for them might find a good kit like from Anderson & Forrester?
philbotha
Watch-makers also use ultra-fine tapered needles and reamers in their trade, available as sets.
-Phil
It's a lot of difference in the application. An easy way to think about it, order a 16" pizza. Order an 18" pizza. Set them side by side and see how much more pizza is really on the 18" compared to the 16". It's the same principle, just a lot smaller. And when you consider that the needle is usually only .001 smaller than the orifice, it's plenty to make a difference.
