GJ
5AE25A9E-609F-4552-BAA6-DB4274B0AD67.jpegHere is a new one for me. Tearing down this 200A and noticed turning the tip cleaner did nothing, so took it off and found it broken, taped all around it trying to get the other piece to fall out and nothing. Any suggestions?
JustOneMore
I would replace the whole valve assy. Shoot me a PM if you need one.
Dana
If it has a flame, I like it.
While it is certainly nice to find what you collect, in reality you must collect what you find.
The Coleman Blue's 243's #009  BernzOmatic Appreciation Club #029
MilSpecOps  #1972   ICCC #1378  Coleman Quick Lite Crew #37
"Tearing down this 200A and noticed turning the tip cleaner did nothing, so took it off and found it broken, taped all around it trying to get the other piece to fall out and nothing. Any suggestions? "
Is the eccentric block still in the valve assembly? Is the eccentric lever packing still in the valve assembly? This is an issue that might be able to be repaired.
Taco912
I just replaced the broken lever on a 202 with one ordered from OCP.  I put a torch to the valve where the lever goes in and the packing popped out and landed on the bench.  I removed the eccentric, cleaned and replaced.  I had read here that installing and aligning the lever and eccentric was a tedious process.  Might have been beginners luck but it went smoothly. I placed the valve in a vice with the tip cleaner pointing, centered the eccentric in the hole and holding the cleaner lever in the 3 or 9:00 position screwed the new lever into place checking that the lever engaged the eccentric hole.  Be sure to leak check the tightness.
Coleman 243 Blues  #812
Dvan95
Since the bushing is stuck in there you're going to have to heat it up with a torch nice and hot and see if you can pry a small seal pick or screw driver in to pull it out, then remove the eccentric block. Installing a new tip cleaner will be a piece of cake after that. If not, just replace the valve assembly!
-Dan
Coleman Quick Lite Crew #048
