Picked this one up yesterday, figured I'd start on it tomorrow when I get back to work. Didn't have a lot of time to look at it, but noticed it will need a burner tube. Assuming the fount is sound I wanted to go through my parts and try to dig up an air tube for it. Are these the same as a quicklite or 220/228Bs? I should have parts for either. Hopefully they are not slant only. Something else I'm noticing is the pump to the left of the valve wheel.. my slant big hat is to the right... Which is correct? My book is at the shop as well... Thanks for any help and have a nice day.
Gavercronos
That one's been apart before, the clocking is uneven. Of my eight, six tightened up 180* off what you'd expect, so no worries. As for the burner tubes, some had regular length and some had short tubes on them. If you can't tell which you have, just get a pair and you'll be OK.
WillCat
Chautauqua County, New York
Thanks Will, I figured as long as they're the same length it'll work.
