Guff
Two weekends ago my wife and I went on a small road trip around to some of my honey holes, and came home with six lanterns which I subsequently showed in Just Bull. The last few days I worked on getting two of those finds, which were in the worst condition, cleaned and fettled. One is an aussie Handi Kero Pet, and other is a Canadian 339 kero export model.
Here are some pictures of the before and after. Nothing outstanding, but the processes involved a considerable amount of work to bring them back to working condition, and looking half decent.
The main issues were both founts had issues with verdigris and rust affecting the nickel plating, both had black gunge in the inside of the founts, and almost every seal had to be replaced. The 339 had bad rust on the steel fount, burner assembly, globe cage and vent, and the Handi had a badly pushed in fop of fount as well as rust issues to the cage and vent.
Here are some before pics showing their condition. Certainly not beyond hope but requiring some work.
Here is a pic of the badly pushed in top of the Handi fount, after I had done a hot citric acid soak and lye soak inside, and BB shake and evaporust soak inside as well. As you can see this depression is very deep, but I was confident the freezing method, which I have used for the past ten years or more on all types of depressions and dents to founts, would pop it back out.
And here is the result of the freezing method. It took 12 hours to pop it mostly out, and there was no damage to any of the other fount parts. I pretty well know how long I can leave the fount in the freezer for a great variety of depressions and dents as I have used this method many times over many years.
Some dents like creased and bullseye ones, you can not improve them much so don't persevere with the freezing as you could end up bulging the fount or doing other damage.
This looks pretty good to me. All I need to do is tweak the valve slightly to ensure it is perpendicular.
Here are all the parts after cleaning and polishing them.
And here are the lanterns back together again.
Before I could do the money shot I had to make some wire coils for the 339 generator, as they were missing. I made these out of copper wire. One fits inside the other, so you have to get the diameters correct. They worked very well on the 339 as seen in the money shot.
And that's it. I will go looking for two better vents to improve their appearance some, but I'm happy with how they turned out. Thanks for looking.
Keith.
Guff that’s an interesting fettle and awesome turn out you did. Love the Handi Kero and looks like you are pretty good using the ice method. I have a 200a with a big shallow dent on one side that I want to get rid of it, I think I’ll try your method.
“Solo sé que no sé nada”
austin65uri
Enjoyed your post. How did you get such uniform copper coils for the 339 generator? I've tried that with much less success.
Bill.
ICCC#1601
CaptainFantastic
Two great saves, Keith. Nice work on that fount and the generator.
Guff
@Pancholoco1911
Pancho, If it's a shallow dished dent on the side and not on the curved part of the fount, and not veed or creased in the bottom of the dent, then it should come out ok.
A steel fount is a little bit harder than a brass fount to pop them out by freezing.
Some members here use a heat and added pressure method. They fill the fount with boiling water, then add pressure with a compressor via a schrader valve or a grease gun to pop out dents.
Me I like the freeze method because it is a very slow process. As the water freezes, it slowly expands and gradually pushes the dent out. It doesn't happen immediately, like adding air from a compressor. That gives you plenty of time to check it's progress periodically, and also to check that the bottom of the fount, or somewhere else is is not bulging or being damaged.
I've never done any damage to any fount I have used this method on. Just do some checks as the dent starts to move on it's outward path.
I would be very careful using this method on large diameter founts like some of the lamps though, especially ones with a brass base plate,and some of the later Tilley lantern founts. IMO this method in quite safe as well.
@austin65uri
Bill, I simply use phillips head screwdrivers of various diameters, as mandrels. Put one in a vice and wind the copper wire around it to form the coil, pulling the wire tight on each turn. I just gauge the spacing of each turn by eye. Practice makes perfect.
I will get my wife to take a photo and will post a picture of the set up next time I do one.
Wow, that's some amazing work, Keith.  Definitely a labor of love to do that much work on two old lanterns.  Thanks for the details on your freezing and coil making also,
borntoride
Guff, great write up and repair.  Thanks for posting the pics and the directions on the freeze method for dent removal.  Good job on making the coils.
Thanks again.
In His service
borntoride
Pray or become prey
275 Appreciation Syndicate member #0091
MartyJ
The Handi Kero Pet should be named Lazarus!  Quite a transformation.
Marty
What a transformation! Nice job removing that dent.
mgmlvks
Great work and report - thanks!
Francis Bacon
Very impressive work!  Especially the fount dent repair!
They both turned out great. Excellent work.
I agree.Very impressive!
Coleman Slant Saver #50
Coleman Quick-Lite Crew #18
Dvan95
You completely turned the lives of those lanterns around! Nice!
-Dan
Coleman Quick Lite Crew #048
Guff
Thanks all, for your appreciative comments on this post.
Now, on to the next ones in the queue.
Keith.
I'm New to this whole hobby . I've had a couple of Canadian 236 lanterns for years and a 200A but just got in to collecting and restoring. Guff has enlightened me considerably.....I would have walked away from those two lanterns unless they were so cheap its might be worth it for future parts donations. I am familiar with having donors cause I was into old Willys Jeeps for years and years. Never say never I guess! Thanks Master😁
Quote:
Actually, after reviewing the before pictures I realized the Coleman was pretty much typical of what I do pick up around these pats... but the Tilly!!!
Quote:
Oops I mean the Handi....
Quote:
Guff
@Jeepstircrazy.  Hi Wayne,  thanks four your kind comments on my post. Pleased to hear you got something from it.
I need to say that I certainly did not invent the freezing method of dent emoval from gpa founts, but I've had lots of experience using the method.
I first saw the method described on the old BBL (Be Back Later) site. That was a very good site on which many of the fettling processes and procedures that are repeated on sites today, were first described in detail, before other gpa sites came on the scene. I also learnt about using molasses and citric acid for rust treatments there and also learnt how to remove an reinstall pump tubes to founts as well as many other fettling techniques.
That site is long gone but there were some very talented members on it who compiled and posted lots of very informative posts there.
I don't know if those old posts were ever saved and archived, and can be accessed still, but suspect that it may not be.
When I get home  (I'm presently up in the wilds of Cape York Peninsula) I will photograph and post some pics of the creased, bullseye and other types of commonly found fount dents, and include them in my post's body.
Keith.
Sounds good Keith,  Today I sold a Yanmar tractor that had a crack in the block and told the guy before he drove an hour over here that I would take 30 bucks off for each old Coleman lantern (no Propane! ) that he might have. in decent shape.. I got a nice 242C and three 228 E lanterns only one 228 had the glass but one did have a flint striker. Bought half of a collection from the son of an outdoorsman a week ago and got one of the 237's he had and will get the other 237 tomorrow with a BLUFLAM brass stove made in England. That will give me a total  of 8 pieces $30 bucks each. I'm thrilled and have more projects for this winter than I can shake a stick at!  Once I figure out how to post pictures here and keep my better half from seeing all this stuff I'll post some before and afters. I finished another 242C and a 228F but have over 20 more to attend to. This beats the heck out of blacksmithing with two rotator cuffs gone and tennis elbow to boot. Still playing with fire too! That one quote about" fine line between hobby and insanity" is spot on! There don't seem to be many collectors in these parts or I am just real lucky.... now if I sell four of my anvils and keep one I'll have more money for lanterns!!   Wayne
Quote:
Smudge
Great restoration job. Thanks for posting the details.
BillG
As a new member and new to the hobby, your work is inspiring...thank you!
