Djpruett
I just found this Thermos stove at a Garage Sale this morning it’s in very great shape
Nice score. Was it even lit?  Looks untouched.
surffisher60
no bacon grease  ?
bob
That's a beauty!
>>time to do some research on this!
If that's a combo fuel cap and pump as it appears, search for Thermos pump for info on rebuilding it if not already familiar.  That's more than a suggestion.  It's a bad design using four O-rings in the pump, but the one under the poppet in the end being the most critical.
Djpruett
Yes it was used but maybe once even has the thermos stand new in box never opened.
Djpruett
no bacon grease  ?
bob
nope not one drop.
That is fun..  even has that splatter shield thing..
Jim is right, that is not the safest fuel pump design..  fill full of fuel, pump it up, DON'T LIGHT STOVE  let it sit a few minutes, give it another pump or two and see if any fuel is in pump tube and comes out.  If orings are bad (they usually are) fuel will get into pump and spray out when you go to pump. This is a good way to start a nasty fire if stove is lit when this happens. Let us know if pump get fuel in it and we will go from there.
holliswood
If the pump gets a chub after pumping it up, you’ll have a mess or a blazing mess. Even if there’s no issues, don’t turn your back on it and use/light outdoors.
-Fred
ICCC Member #1871
MilSpec-Ops #1278
Coleman Quick Lite Crew #41
CANADIAN BLUES SYNDICATE #57
Coleman Slant Saver #65
snipesfred on Insta
Big Ferd on YT
Fred....[sSig_heeheehee]
holliswood
-Fred
ICCC Member #1871
MilSpec-Ops #1278
snipesfred on Insta
Big Ferd on YT
