Got this from @StanDahl in the mail today...
IMG_9232[1].jpg  A little oil on the pump cup, figuring out how to run the little air check valve, and the tank holds pressure.  Well..... I have some CF at the shop...
   IMG_9226[1].jpg  Genny pisses into cup....how about that....wonder what happens if I shift burner forward......
 lots of cool green flames that don't show well in picture.  I have some clean up to do but this is a solid old stove will be cooking soon.
IMG_9231[1].jpg  Burner doesn't seem to center well under  grate, will work on that. Secondary stuck as well, am sure is no biggie.  I like the removable oven parts, am wondering a bit what is supposed to hold wings out ?
 Gads I love old stoves, and my mid-section is showing it.
liseverewx
Wow. Great stove. I’m sure with a little TLC it will be running great in no time.
Love it.  Keith, see if the burners can slide over more.  On mine, I wasn't moving them to the right enough and didn't have real good flames.
That’s cool! I really like the flame pattern from those style burners.
Duane, thanks for the thoughts. Am sure it will center with a little rust removal 🙂
Had a lot of "things" coming out of the burner, am sure things will clean up.
I have a #2 that I have been using a lot, this valve/genny on the #1 shuts off much better than the #2.   I like.
StanDahl
That's great to see! I haven't had an oldie let me down yet - Coleman anyway. What holds the wings out?
Nothing.
They are either square with the case, or completely laid back. With the solid grate, there isn't much need for wind baffles.
(That's my #2 that's even more rusty than your #1 there.)
The auxiliary burner looks like this underneath:
It's probably seized up here, it shouldn't take too much to set it free. That round bit with the hole in it rotates on the wire shaft to get the fuel/air mix into the burner. It seems to be easier to get apart than the #2.
I figured you wouldn’t be able to wait long before firing it up, Keith!  That stove went to a good home and we’ll going to have to see some grub shots down the road!  That’s a beauty for sure and the flame looks pretty green from here.
MrAlexxx
That's real nice! Nothing like getting an oldie burning again.
Alex
Very nice!
Flat_twin
Woohoo, FIRE!
scl
great.
SteveA
I've never seen a stove that old in the wild, if fact the only stove I have with cast iron burners is an AGM, which runs great.  Are you going to do a full restoration on it? Can't wait to see it.
@SteveA I will not do anything like a full restro. It will be made functional, clean up the rust a little, probably a quick coat of black for a bit of rust control.
I leave nice work to some of the experts on here.
