Was looking for pips for my SVEA filler caps the ones that take an air pump and had no luck on eBay. Where do you guys order yours?
Thanks in advance
Click image for larger version - Name: B0F98649-4D42-475A-8090-C958CCEC23E1.jpeg, Views: 52, Size: 200.80 KB
Looking for B-Day lantern 9/83, 7/85, 10/04, 5/11, 2/19
https://fettlebox.co.uk/index.php
Didn’t wanted to go that way but I’ll have to. Thank you Steve
edit: no pips for this caps
Should be, the offerings are two sizes usually.  Let me look.
PS:  I see two sizes, 4 and 4.5mm.  You need the 4mm I believe.  Look under seals and washers.
If it isn't leaking leave it.
pips are hard as a rock. I need to order them. Thank you!
Found this thread and they don’t work.
I remember Timm @Gunhippie talking about these filler caps not long ago, I will read what he post on morning
the style pip your showing is no longer available BUT he has a tiny brass cup that holds a pip as a replacment , they work great .
Thank you Steve, I'll go back and look for those brass cups
the pic doesnt look right , email him he is good at answering questions and showing you the right part .
https://fettlebox.co.uk/svea-123/123r-filler-cap-seal-safety-valve-pip.html
this shows the new pip holder pretty good
https://fettlebox.co.uk/non-return-valve-refurbishment-kit.html
Found one at my stash from a NRV euro stove and works right now. Thanks for the help and I’ll order some spares. Happy Father’s Day!
