Skydivedave
Hi all, can anyone steer me in the right direction for a valve wheel for this SMP milspec? Picked this up at the flea Saturday, barely used and in great condition except for the missing valve wheel. Funnel and tools intact. I didn't need another milspec but I didn't have an SMP version and the condition is nice.
David  Click image for larger version - Name: MVIMG_20200714_105153_compress7.jpg, Views: 40, Size: 266.66 KB Click image for larger version - Name: MVIMG_20200714_105622_compress61.jpg, Views: 40, Size: 238.63 KB
Click image for larger version - Name: MVIMG_20200714_105239_compress96.jpg, Views: 39, Size: 163.77 KB Click image for larger version - Name: MVIMG_20200714_105256_compress63.jpg, Views: 39, Size: 235.97 KB Click image for larger version - Name: MVIMG_20200714_105453_compress25.jpg, Views: 40, Size: 80.77 KB Click image for larger version - Name: MVIMG_20200714_105539_compress0.jpg, Views: 39, Size: 187.89 KB
Mil-Spec Ops #1957
BernzOmatic Appreciation Club #052
Coleman Slant Saver Group #61
you need a new valve shaft , wheel , disk n a screw
Skydivedave
Thanks Steve. Where in the world would I find this? Interchangeable with Coleman? I hope?
Mil-Spec Ops #1957
GCinSC
Is this it?
https://www.oldcolemanparts.com/search.php?mode=search&page=1&keep_https=yes
Mil-SpecOps #0308
This should do it:
https://www.oldcolemanparts.com/product.php?productid=132&cat=&page=1
GCinSC
Chuck,
Same part I picked but my linky no goody.
Gary
Mil-SpecOps #0308
Hmmm, when I clicked on your link all I got was the first page of all parts for the 220's. I just clicked on mine again and it went right to the valve?
Anyway, Cigar Mike has the entire valve, F/A tube, shaft, knob and screw good on 220B-F's I think it said.
you would think a regular 220 shaft would work here but i tried it once with a SMP and a coleman shaft wouldnt close all the way in the smp valve .... if you have a 220 shaft try it n see .. cant remember what i did it was long ago .......probobly a whole 220 valve n shaft would work , there pretty common . sorry i dont have better advice .
GCinSC
Chuck I didn't select ONE part my "link" was for two parts, complete new and a wheelless used.
I installed one of those when I mucked up a valve on removal, won that battle, lost that war.
And Dave, you're about 1.5 hrs up 95 from me.
Mil-SpecOps #0308
Skydivedave
Wow thanks everyone! This helps immensely!
Gary, we're just far enough apart not to step on each other's toes! Although occasionally I do sneak into your area if i see a listing of interest! Lol!
David
Mil-Spec Ops #1957
I tried to put a 220 B-F valve assembly into a 1963 King Sealy-Thermos fount and it would not work. The threads were oh so close, but not the same. I ran into the same problem that Steve talked about with putting a Coleman 220 valve shaft into the Mil Spec valve body, it would not shut off all the way. I was able to clean up the tip of the 252 valve shaft enough so it is working now, but it also will not shut off all the way. I will just have to look for a beat up 252 for the valve assembly. Just throwing this out there that it may not be as easy of a fix as you would think. At least for a non Coleman 252.
macwacs
A real good machinist could turn the wrecked shaft down and make another that was a tight slip fit over it. It would be fun to make it maybe two or three times longer than original just to confuse us collectors when they see the special extended long control shaft. Only one of a kind special order.
RMW
