Doug L
This slant appears to be dated March 1928. It’s my understanding that March is the first month and 1928 is the first year of the slant.
 My question is why does this have the  th control knob Click image for larger version - Name: 898EF6A0-C809-445E-9556-462B2E0D145F.jpeg, Views: 136, Size: 52.65 KB Click image for larger version - Name: 5968D060-381A-4105-A095-FA8AAB46CE4C.jpeg, Views: 139, Size: 39.44 KB
Click image for larger version - Name: 9389BE0E-0C98-443B-94F9-2CBF3A8873A6.jpeg, Views: 135, Size: 47.45 KB Click image for larger version - Name: 35D008A0-5637-427D-8AAA-1960109CBFD9.jpeg, Views: 140, Size: 50.88 KB
looking for a Hugo Moller Comet  Stove 5 or 6
coleman54
Hi Doug, nice slant. It is obvious the valve or just the valve stem (later knob) has been changed, it also appears the as designated valve bracket wedge was left out beneath set screw.
Larry
Inquiring Minds Want To Know
the wedge or as i call em T SHIRT :-)
kw12330
This is the part Steve calls the T-shirt and it is missing from your slant. It should go between the set screw and the valve assembly.
http://www.oldcolemanparts.com/product.php?productid=3883&cat=&page=1
Keith W
ICCC#1599
looking for lanterns 1/66 1/87 7/94 BernzOmatic Appreciation Club #011
The Coleman Blues 243's #112   MilSpec Syndicate #1966
Coleman 275 Appreciation Syndicate #168  Sears Collector Club #1966
Canadian Blues Syndicate#49,Coleman Slant Saver#1966
i made my own T shirt once  . i cut a piece of sheet metal with a hack saw  , then hand filed each side . i came out so nice you would hardly know it was home made but for 4 bucks id probably just buy one next time  :-)
Mister Wilson
I made one out of a penny, ground the sides and made a T.  It’s still in use, works great.
i was given a pretty large bird aviary once , all i had to do was get out of there back yard and bring it home .....anyways its a steel frame with mesh attached by drilling a hole thru hundreds of pennys and using as screw n washer to attach this mesh ..........i still look at all the penny wise work today .............. how much do washers cost , probobly more than a penny !!!!
Doug L
 who sells them
Mister Wilson
Doug L wrote:
 who sells them
See #4.
58idaho
Old coleman parts had some.
Doug L
Thanks guy. EC682B47-F25B-418B-A0E3-4B6E8D34F93F.jpeg D2E6F756-4940-414A-A16F-B45D035631CE.jpeg
Mister Wilson
Cheap fix!
OregonMichael
Love that!  A $.01 part...
