Now to look for more appropriate burner parts and see what happened to the fuel stem...
Just glad to see it making fire again ðŸ˜
Very nice Toby!
Leviticus Tomethreus
Cmon Levi, which Q is it? Let’s see I know of B and C. Does DQ count? Alright, Levi’s final answer is (drumroll please) CQ.
if they did call me that.
Thanks Greg, hopefully will get nicer, had checked for pressure leaks over the weekend and when that passed I thought I'd at least make some fire before I pull it all apart.
Levi, your close. From what I've learned this was right before the famous CQ... I'm still learning these older lamps myself...
So it’s literally just a Q lamp?
coleman54
Looks good Toby. 👍
Larry
Inquiring Minds Want To Know
Thank you Larry, and I appreciate all your help with this project as well.
Levi here's you some reading material from Larry, I still need to read it a dozen more times before I can even pretend to know anything ðŸ˜
https://www.colemancollectorsforum.com/post/c-fount-%E2%80%9Cq%E2%80%9D-lamp-9908679?pid=1306083612
So let me just pretend that I read all of that that. Well that was some great info. Pictures were cool.
Sorry no pop up pictures for the kids Levi ðŸ˜ðŸ˜‚ just messing with ya squirt!
Why are you guys just so out of this world to me. Like pop up picture as in those books? How are you messing with me?
I'm just teasing, no worries
Your “teasing” is too complicated for me
Levi
You need to dig deep here and buy the book.
I am not sure Toby referenced the best post from Larry. His post does mention this lamp at the beginning in text but the pictures and discussion surrounds the next later lamp.
I am not sure if Toby's fount is marked, but my understanding that fount started as an M lamp which was torch light and when it was changed to Q70, quick lite burner became the Q lamp.
Notice this difference in the founts depicted in the link?
Thank you
I frighten easily!
@Tgarner01 No disrespect intended!!!!
@Leviticus Tomethreus here is part of the story that predates the earlier link.
https://www.colemancollectorsforum.com/post/my-first-model-m-lamp-10629442?pid=1312455222&highlight=m+lamp
I frighten easily!
Thanks Kevin, I had forgotten about Greg's lamp. There is some more detail given in that post. Not a lot of Q lamp info left on the forum that I can find. Probably because of the short run and 100+ year old age ðŸ˜
coleman54
Levi
Thank you
The link to the post written above is information from my research you won’t find in the book that was unknown by the authors at the time of its publishing.
Below is my example of the first turban fount
“Q” Lamp (it is also shown on the Terry Marsh site).
@Whitegas Extraordinaire
Larry
@coleman54 now that is a cool lamp.
coleman54
Thank You Levi. 😁
Larry
Thanks for sharing that beautiful example Larry. A PM coming your way shortly with some questions on the other Q lamp project..
Thank you for your research Larry!
I frighten easily!
coleman54 wrote:
Thank You Levi. 😁
Now I need to find me one for a 60th of retail price. The hunt begins.
PXL_20200911_195215249.PORTRAIT-01.COVER_copy_786x1048.jpg  PXL_20200911_195242487.PORTRAIT-01.COVER_copy_997x1329.jpg  PXL_20200911_200244722.PORTRAIT-01.COVER_copy_876x1168.jpg  PXL_20200911_200434467.NIGHT_copy_725x967.jpg
Little progress being made today. I swapped fuel stems from the drilled fount Q over to the good fount, which meant I had to solder a new pickup tube to it as well... Just so I could have the original nickel handle... Still working on finding an original air tube to have a correct valve/burner assembly.. But figured it may take awhile so I just used the later valve/burner for now. Fount has several little dings and one good one which I forgot to picture, but I believe it shined up fairly good for 100+
Progress being made on the drilled fount Q as well... Small issue with dirty solder joint.. Hopefully an update coming next week. Until then, thanks for looking and have a nice weekend.
Wow Toby quite the set up in the background. Your Q is looking great
@Tgarner01 man I need to stop lookin at your posts. Almost shed a tear looking at the background. Lamp looks great, so does the HGP. Is that some kind of Tilley on the left? One of the heaters or an fl6?
Thanks Ken & Levi, sorry for the grungy shop pictures. The mosquitoes were out with force today so I sheltered inside ðŸ˜
Good eye Levi, I believe it's what's left of a Tilley R55? I'd have to look it up again.
Very nice. I’ve been really keeping an eye out for a nice fl6. I bet that’d be nice for night fishing in a private pond.
I'm not up to date on Tilley's myself, just thought I'd save it back for a Frank project someday
The only reason I know what a Tilley is, is because of  https://classicpressurelamps.com
     That’s where I started with the gpa thing because I though ccf was too complicated.
coleman54
Toby, that first version Q is starting to make me drool. 😁👍
Larry
That's saying a lot coming from you Larry ðŸ˜
Assuming I can get the valve/burner assembly back to original would you know which shade/shades would have been original too the Q lamp? Not much info I can find on this particular lamp. Looking back on your 334 shade writeup I realized it was introduced several years later.
coleman54
Toby,
The first “Q” came standard equipped with no. 307,
but you could have any shade available from Coleman at the time by paying the price difference between the two.
Effective :  July 1 1916
Larry
Thank you Larry, now to find one ðŸ˜
That shade looks good on your Q. They really work well together!
coleman54
2B21091E-C44C-4537-A060-BCC09CF64C90.jpeg  53BA4BBD-2EB0-4110-8C08-0860DA44CEBC.jpeg  168CC9E7-9FA3-4972-8276-5F9F496817B0.jpeg
Larry
Thanks L.J. Larry thanks for the info, and what a beautiful lamp!! Thanks for sharing
Gavercronos
I got a repop 322 shade for my M from Lehman's:
The original 322 was, I think, milk glass, but this looks nice too.
WillCat
Chautauqua County, New York
That looks great Will! Thanks for sharing. I bet these small fount lamps broke a lot of shades. I never realized how much smaller of a footprint they had compared to a CQ.
