I recently picked up a PW308A stove and I have a question regarding the pump assembly.
Here's a picture of the pump assembly.
[IMG-2826-Copy]
It appears that the pip is gone.  What do you folks use to make one?  I know it has to be fuel resistant.  Do you folks just find some buna/viton material and cut one up until it fits or is there a source where I can locate one already made?
[IMG-2829-Copy]
Thanks!
I usually buy a Buna o-ring of the right width to fit the cup--the biggest one I can find. Use a very sharp blade and cut off a section so it sticks just barely out of the cup and you should be good to go.
There should also be a Buna or Viton gasket under the top of the pump tube to seal it to the tank. I used some concentric punches to make mine, but don't recall what the sizes were.
I can mail you a pip if needed.
Thanks, Timm.  Yes, I forgot about the tank sealing one at the top being that it is tucked away and out of sight.  I appreciate the heads up.
I just punch em out of whatever I find in my spare gasket pile 🙂
I have a piece of Buna I bought just for this years ago, it works well.
The Oring trick like Timm is talking about....I struggle to get a flat enough surface, need sharper blades or steadier hands. But it does work.
Just a note, often when I do a new pip it leaks to start with. Leave it there over night, they usually kinda seat and work well.
Many originally had cork gaskets. I use BunaN or Viton from flat stock for PIPs, 1/8th to 1/4in. thick depending on the application.
Thanks for the advice and tips.  I haven’t worked with a lot of stuff that incorporate pips in the design.
The problem I've had with making pips from Viton is that most Viton is too hard--70 Duro or higher. Most of the Buna material I have is 55-60 Duro and seats much better. For falt gaskets, this doesn't much matter.
For fuel resistance and durability, there isn't any real difference between Viton and Buna-N in the environments we use them. Viton is better at extreme temperatures, and Buna at very low ones--but both are well outside our window of use.
