johneliot
I just pick this lantern up for $7.  I didn't really need the lantern but it came with 2 packs of silk light mantles, so why not?  If I got it, it needs to work.  But... it leaks when I screw on the canister.  I figured it was that corkish gasket.  Is there a place where I can buy  a replacement?  I didn't see one at OCP.  Is there any place else that could be causing the leak?  The soap bubbles come from that connection where the tank screws on.
― Albert Einstein
I love that orange vent!
Would this be the gasket you need?
http://www.oldcolemanparts.com/product.php?productid=2086&cat=&page=1
johneliot
I saw that and the outer diameter is right but the inner diameter is not right.  It’s too small.
― Albert Einstein
johneliot
I do have the mushroom lantern and a 3 burner orange stove.  They are kinda fun in a 70’s way.  If i find a 2 burner at a bargain price I’ll add it to the collection.
― Albert Einstein
johneliot
Jim, I checked that one out and while the OD is right the inner diameter is too small.
― Albert Einstein
If just the ID, I personally would go for it.  I figure it'll have a little give to fit, or I'd probably try to punch it out bigger.  Although I wouldn't have a punch that size, I was thinking if you took a pencil and removed the eraser, you could use that barrel as a punch to take a little out at a time until it fit.  Not pushing you either way, it was just a thought I had.
Rustytank
Harbor freight has a set of chisel type hole punches fairly cheap. Or you could measure the I.D. of the old gasket and freehand it with an exacto knife.
Check the gasket kits at Harbor Freight. They have one with an assortment of gaskets. There was one in there that fit the Coleman propane gasket like this really close. I used it on one of my Propane lanterns. I have one of the Sears lanterns. If I get the time, I will see how close they match.
johneliot
Thanks Dan.  I’ll check into the Harbor Freight “stuff”.
― Albert Einstein
Also check a real hardware store if you are lucky to still have one in your town.  If they don't have the right part they maybe can order it or tell you were to get it.  While I admit to going to HF, it is my last resort since most products are cheaply made and made in China.
hahoe03
If it is cork, try putting a drop or 2 of oil on it and let it soak in. I've done this on a couple with good results
Mike Trigg
The Coleman Blue's 243's #053. Sears Collectors Club #69 (pending)
Lant_ern
I gave this one to Eric Baylis before his 2016 passing.It looked to have only been lite once or twice.
Looking for a 7-55 Canadian lantern       Ernie
BRIGHTER IS BETTER
Canadian Blues # 37
Rhubarb
Would this one work?
https://www.oldcolemanparts.com/product.php?productid=2086
Order a grip of well priced mantles while you are at it.
Andy  -- "It was a pleasure to burn." Ray Bradbury
1_BURNING_HODAD
[QUOTE username=Rhubarb userid=2134117 postid=1310559196]Would this one work?
I have order these and they work on propane lanterns and stove regulators.
I'm a user, not a collector (yeah, right).    ICCC #1229
Semper Crapulatus    Greg aka "Old Man Teague"
