bear549
Hi,
This is sort of a Coleman question. The generator (jamb) nut on my Preway L46S is cracked. I tried one for a 220/228 (since it uses that generator) and it threads on OK but the Preway nut is a little taller. Will that be OK or is anyone aware of a replacement?
Thanks!
Chris
"Got time to breathe, got time for music". Briscoe Darling
Yes, it could be okay.
Pump it up, rotate the pricker lever up, open the valve under pressure without firing it and you'll get your answer. Careful to not let the fuel from the gen tip run down as it may look like the jamb nut leaking.
bear549
Thanks! She's apart right now but I will certainly do that.
Chris
