CoachT
Good morning all, I recently took possession of an old Coleman Powermate 54 generator that I would like to get running again.  I have been searching online for the owners manual with no luck.  I reached out to Powermate with no luck, and was wondering if any of you might know of a resource for finding old manuals.  It's a Coleman Powermate 54 model number 544020 with a serial number of 86171253 or 55 the last number is tough to make out.  Any help is appreciated.
I love the smell of Coleman Fuel in the Morning!
Coleman 220K 09/1980
Coleman 285A 10/2012
Coleman 413F Stove
Colemen Powermate 54 3000W Generator
egroscup
I looked those up and it appears to be a standard float carb Briggs and Stratton. It shouldn't be too tough to get running. It should have a Briggs model, type, and serial number on the engine. It may be easier finding info that way. I would also pull the end cover of the generator off and grease the bearing. Get it running and then we can figure out the generator side. E.
Erik
CoachT
Thanks E, I got contacted Briggs and Stratton and they emailed me the manual. I ordered a $25 kit off of Amazon that had a fuel filter, fuel shut off valve, new carb, new air filter, and a new plug. That was a no brainer. Old carb was completely locked up. I have it running and it does generate power. I tested by plugging a box fan into it. Still needs a good clean up but for having a total of $65 into a working generator it was worth it. I’m not sure what you meant by the bearing that needs to be greased on the generator side.
Coleman 413F Stove
