10gage
So I’m cleaning up this Nulite and am running across things that someone rigged up by using a q77 gen where somebody packed the jamb nut with thread material and packed the fuel cap with thread material as well. I know that’s not correct however there is also 96FEAD56-2980-432E-BCEF-723412142227.jpeg  96C8603C-4D9D-41D3-8241-316E1931C435.jpeg  what appears to be leather in between the pump assembly and I’m assuming a washer that sits against the fount flat. Is this correct on any Nulites you guys have seen? Also what size oring should I use on the gas cap insert? Thanks in advance
James sizemore
milspec syndicate #1941
slant savers #68
quicklite crew#43
bluepen61
Is that a lead washer seal and you are missing the lead washer?  And I don't understand where the Q77 enters the picture.  I have a model 8 which appears much different than yours.
John L. Kemmis ICCC #703
Bernz Appreciation Club #007
and the usual unusual ones.
10gage
i just tried pulling it off and yes it is a lead washer I’m confused about what’s in between and if it’s supposed to be there. As far as the q77 someone tried running that in place of  the proper one.
James sizemore
slant savers #68
quicklite crew#43
10gage
I just went to remove the pip and it appears to be leather as well.
James sizemore
slant savers #68
quicklite crew#43
People without access to a supplier or close to town or even without funds used leather.  Some of my old Primus stoves used leather in various areas.  I've run across leather many times.
10gage
I have as well. I found a leather washer on a quick light 327 that I had gotten. I guess I am going to find a O-ring to fill the gap on this one. I’m assuming that the lead washer was probably smashed a little to much and the leather filled the gap17FFCBF8-CA56-45AB-A27B-A41443B4A184.jpeg  4D54DC9E-DFE8-4F1E-8B72-49619816D7AF.jpeg
James sizemore
slant savers #68
quicklite crew#43
I see thread tape in a lot of wrong places where someone who didn't understand how things work tried to fix a leak. One common one is on flare and compression fittings, where the threads were never meant to seal.
arghhh.  If I had a dime for every time I had to undo someones crummy flare connection thats sandwiched with Teflon or compound...   I can always tell when an amateur came in ahead of me on a job by flare connections.
10gage
If your familiar with the Nulite gen it has a male end that fits into a female valve. This one had a q77 female going into a female valve with packing thread wrapped around the gen and the Nulite jamb nut 6F92F64B-EF21-45A8-8D6D-2AFC0BE94D60.jpeg  C50182DE-3799-445F-BF40-9766008357D6.jpeg
James sizemore
slant savers #68
quicklite crew#43
