100LL
There’s just something about a nickel fount that is appealing to me.  Ever since I got a 242 in nickel dress I was smitten.
I really love the 242, and got motivated to step up to the 236.  I got one in that needed some fettling, and proud to say I got her running like a song!  Oh what a blinding and beautiful sight!
The 236 was a bargain and I did m best to brighten her up, with mild success on the nickel fount, upon which there was certainly a fair amount of loss.
could ramble on more but let’s get to the point.  Regarding nickel plated founts I’m asking for advice and techniques regarding;
  1. Repair of nickel plating, particularly the missing spots where some corrosion is occurring.  Is there a polishing technique.
  2. Re-Plating; practical, affordable, what’s involved?
  3. Preservation; how to not let things get worse.
thanks for the discussion.  It’s amazing the wealth of knowledge on this forum, and the willingness to share it.
attached are a few “before” photos of the 236.  I’ll post some current photos tomorrow.  Click image for larger version - Name: 8571F6FB-0AA5-48F5-8F0E-96E7B2ACD2D1.jpeg, Views: 174, Size: 147.49 KB Click image for larger version - Name: 9B10A72A-6713-468A-AD97-B08D50F34A62.jpeg, Views: 171, Size: 116.93 KB
Click image for larger version - Name: EFD7594A-D37F-4688-86D7-1E8F047A7962.jpeg, Views: 175, Size: 109.46 KB
Tyler Hall
ICCC #1876
Looking for a few good lanterns:
236 USA (already have 3 Canadians), 202, 243, Col-Max, Optimus 8
Bdays wanted of any type, lantern or stove, for:
11/63  10/75  12/80 1/84  12/08 1/14  4/16  11/19
Thou shalt not covet thy neighbor’s lantern
⚠️ CA Prop 65 Warning: the sky is falling.
Barrett
Can't answer your questions but for me, I'd polish that fount (gently) with so Autosol  (or similar product) and then wax it, as it looks pretty good having survived all those years with just some freckles.
I'm sure the more experienced with have more in depth advice that will answer your questions.
Andrew
Living and learning in NZ
holliswood
I’ve done several nickel founts in the fourteen months I’ve been in the hobby with some cleaning up nicely to some that I felt if I kept pushing it, there’d be no nickel left. If there’s freckles, they’re not going to get any better. The one you have pictured looks great to me. If I were to re-plate a fount, it’d have to be perfect with no dings or dents and everything else would need to be pristine as well or it would look like a sock on a rooster. That’s just my outlook on it.
-Fred
ICCC Member #1871
MilSpec-Ops #1278
Coleman Quick Lite Crew #41
CANADIAN BLUES SYNDICATE #57
Coleman Slant Saver #65
snipesfred on Insta
Big Ferd on YT
MYN
The nickel ain't bad. Just some gentle polishing to even it out a little. Then wax.
It'll look great after that.
Re-plating is a lot work and mess. To do it properly, you'll need to completely strip the old nickel first. Then finish to a uniform bare brass finish. Completely clean and degrease. After that, electroplate. You can do it at home but you'll need nickel salts and the proper plating setup. Of course, some knowledge on chemicals would be useful. Or visit a shop that does that.
I'd forget it unless the raging enthusiasm gets the better of me.
100LL
Here’s the after, which was just a quick dunk in citric acid solution (10 min), followed by brasso polishing and that’s it.
not much improvement. But I do really like this lantern....great runner. Click image for larger version - Name: C7823057-28A5-45FD-99AF-ABE58E4485E1.jpeg, Views: 127, Size: 122.18 KB Click image for larger version - Name: 37736CF1-58E3-4247-9216-06CEA5C4C5D3.jpeg, Views: 129, Size: 115.44 KB
Click image for larger version - Name: 0E958E67-7EDD-4BDB-A2E0-860A2786AF41.jpeg, Views: 128, Size: 117.96 KB
Tyler Hall
ICCC #1876
Tigerfans2
1 shoot some easy off on it, let it set while you watch a game
2 make up some hot citric or vinegar, wrap the fount with paper towels and pour the hot whatever on it
Coleman Slant Saver #58
Coleman Quick Lite Crew #8
Coleman Blues 243's #16
Make sure you get ALL that Brasso off! Brasso contains ammonium salts, which dissolve brass and copper, which is how it works. Any of those salts left on the fount will just make the green verdigris spots worse.
I'd get a bit more aggressive cleaning that. Get all the verdigris off, and the polished brass will be much less obvious against the polished nickel. A good auto-body wax will help prevent any new verdigris from forming in the future.
100LL
Any recommendations for a polishing compound to remove the verdigris?  I have neverdull, and some other automotive polishes like Cali customs which is great for aluminum.
Tyler Hall
ICCC #1876
Mothers mag and aluminum polish. Maybe some 0000 steel wool to very gently polish it to a fine shine.
Mother's Mag and Aluminum polish is probably the most popular here, but Flitz, Simichrome and Blue Magic are also highly regarded. 4-0 steel wool and some elbow grease help a lot.
A longer soak in your acid solution will remove most of the verdigris. It won't hurt sound nickel-plate at all, but may lift some where it's undermined by corrosion.
