Last year I bought and restored an early (peg leg) model 3 as my small stove for minimizing space, if not much weight savings,  and that was successful and I like the way it runs and all but the legs are a PITA  to mess with, and the lid becomes a tray under it rather that a wind deflector.  There are no side deflectors either.  Doable but the slightly later model threes came with the retracting legs, hinged lid, and side deflectors...
So I left my old Watch running, and eventually found a decent deal for one with the wrench even, but lacking the pump...  Still for the cost and the deal I worked for shipping it came to less that what I paid for the first one. (But again sipping was a bit more than the cost of the stove)
It came Friday, and here are the "before" pics - It has been spray bombed on the outside with gloss black at some point, and it has the usual scorch marks for the right side.  It also has one hinge where the spot welds broke loose but I have a spot welder so no being deal there!
I will want to come up with a [ump but the fuel cap does not seen to sue the screw on pump the earlier M3 used?   Its more like the "push to seal" Coleman type?
In any case, here it is as I got it:
The Hing I will  spot weld:
Going to need a clean out...
I have some pumps to see if they are right:
I'm thinking the middle one above may be it?   It has an "grease fitting" tip that looks like it may work?
Looks like you have some work ahead of you. Going to be nice when it’s done.
Yeah,  a bit.  Worth it though!  I won't do a complete paint strip on this one, even though the thing was rattle canned.
Any of those pumps will probably work.
A  junk store an hour away  had a #3 a while back, I didn't snag it and still regret it.
Looking forward to pictures of it cookin!
I tried the middle pump I thought would fit best and it does.  the others probably would work also, but not a solid seat like the "grease fitting" pump
I also compared that pump to my older M3 and other than being 8" instead of about 6,  and the difference in pump handles (the old one has a bent ring handle)  its a match,  he screw on cap has the same threads and knurling.
I took a peak inside the tank and its pristine in there for the parts I can see - It looked plated.   I also pressure tested and everything seems fine.  I'll Evaporust the minimal rust off the outside and call it a day for the tank.
I should get  or make some cap gaskets for both stoves (Did I get some already?  I'll have to check...).  Not sure I have the right size punches though.
MartyJ
I have both versions Outlaw and although the winged one is better designed, my flattop burns as good as any stove I have.  You will enjoy them both!  I think the right pumps are the smaller pump with a finger hold and a threaded small rubber hose attachment but my second one came with a Coleman pump. Now you need a three burner.
Marty
Hey Marty.  Yeah I need to get it cleaned up and some fuel in it.  The tank is clean and the thing hisses with pressure,  but I suspect the burner manifold needs cleaned out...
I do have a later KK 3 burner.  a Mod. No. 99.  The only reference I have for age is the patent date of 1927.  so could be late 20's, but more likely 30's?    I'm not sure if there was an earlier 3 burner for KK.
And I agree, the peg leg burns well!  I used it last fall hunting for two trips and again at Pinnacles.
On the pump for the later stove,  I'm not sure.  I've see several with the short ring handle pump and hose, but this other pump is clearly also AGM (Unless they contracted to another mfg that made pumps for several stove mfg's)
So my search remains active so I can review pumps when they are still there...
Marty,  does the later one with the Coleman pump have a threaded orifice in the cap screw like the peg leg?  (Mine had no threads for the hose type)
I found 2 other pumps in Eprey completed auction listings; one looks like a replacement;  the other is similar to my 8" "zerk fitting " pump (but still had the wood grip).  it has same knurled threaded "head" and looked about 8" long.  it was nickle plated however.    in most cases the orifice did not look threaded, but it could be hard to tell without a closeup
A couple of the shorter ring pumps with the hoses were there also
StanDahl
I've seen ads (supposedly dated 1923, but not verified) that show a Model 10 three burner alongside the peg-leg Model 3.
I wonder if any of the brass cases for the #3 still exist? I suppose a lot of them got turned into ammunition in WWII.
Here is the pump that came with my peg-leg #3. (My two folding lid #3's lost their pumps...well one lost its lid too.) My peg-leg Model 12 has the same pump with the rubber hose too.
It seems to me that the AGM and PreWay stoves used pumps made by the same manufacturer. I have at least three PreWay's with the same pump, no rubber hose.
Here are my two KK pumps side by side.  The one with the hose is from the peg leg stove.  The other was one I picked up "Somewhere", years back.
It's Tip fits the swing leg No. 3 perfectly.  so unless both companies used the ame tip I'm inclined to think this is for the KK, if not the No, 3, one that used the same cap/valve.
And just to complete the pics,  I did have to replace the hose on the smaller pump.  I used some fuel vapor line that I had a heck of a time getting as no one seems to carry decent selections of bulk hose anymore?  Even the "good" parts store (last decent "real" parts store nearby) told me the stopped selling it off bulk reels at all (owners orders,  it was a $$ loser for him - Idiot,  a few "money losers" keep people coming in for the $$ makers.. if that's the case I'm forced to go on line...)
You will note I used the same "string clamp" technology...
Sorry for this poor pic it was from the original Eprey ad - only one I could find with the string stil; there
Still the original hose:
And I'd LOVE to find one with the brass case!
holliswood
@outlawmws
I’m looking forward to seeing the results! Looks like a fun project 👍🏻
-Fred
ICCC Member #1871
MilSpec-Ops #1278
Coleman Quick Lite Crew #41
CANADIAN BLUES SYNDICATE #57
Coleman Slant Saver #65
snipesfred on Insta
Big Ferd on YT
campknot
That's a nice stove. The #3 is a practical size and is good quality. I've got one with the brass case. I'll post a pic if I can get it figured out.
Scouterjan
My peg leg with modified lid has the thread on pump via a brass fitting on a rubber hose. My folding leg takes the regular pump fitting. Both pumps have the loop pump plunger. I have another #3 and if memory serves me correctly there are 3 different ID badges on the case. These stoves work really good
campknot,  I'd love to see the brass version!
Jan, I agree.  I'm really happy with how well my peg leg works.
MartyJ
C77DDE4B-60B2-442E-9F3E-CFA9048667AA.jpeg  169E59E2-9B57-4BBD-911B-8AA950694FDB.jpeg
Outlaw, here is the model 10.  I don’t think it is as old as the ad Stendahl posted but at least late twenties.  As you can see, it has the pump with the hose attachment and a cast iron grate.  My #2 peg leg has the same pump.  The second photo is my #2 With wings and it came with this pump and wrench.  I am sure neither are KampKook but handy substitutes.  The pump looks like a Coleman and the wrench is big enough to work on tractors with. This pump works fine on it though.
Marty
Hey Marty  nice Stoves!  Your 10 looks identical to my 99, even the paint and grate.  I think yours looks to be in nicer cosmetic condition.
What are the patent dates on yours?  the latest date on the 99 is 1927, so possible it 20's more likely 30's
I have a Model 2 as well.  I'll dig them out and see what pumps they have but I'm pretty sure the 99 has an integral pump.   I want to get the 3 burner operational again.
MartyJ
The #10 does have an integral pump.  We (mainly Linus) fixed it a couple of gatherings ago.  It mainly needed a Seal, new pip, and the spring adjusted. Runs pretty good now.  They must of just made a number change at some point.  I will have to dig it out for the patent dates as it is stored at the moment but was going to get it out anyway to bring to the gathering in a couple of weeks.  Are you coming? Nice narrow stove with plenty of burner space. Heavy though with all that cast iron. I think I have a spare tank that needs restoration somewhere.  I just checked and it appears the latest US patent date is 1924.
B67A60C8-1EE6-4C8E-836F-BB8769407B1F.jpeg  EF704A94-DE97-4EF8-8EC8-70AFD85128A3.jpeg
Marty
Yeah,  three years earlier than the latest on the 99.  I may dig that one out later today.  I bought that one at a yard sale two years back for all of $5.  it was missing a leg, but I got that replaced.
I'm going to be taking a pass on the gathering.  Will regret I'm sure, but it is what it is...  I hope to make the one after that.  Take lots of pics!
MartyJ
Was hoping to see you but maybe next time.  I’m hoping the COVID doesn’t throw a wrench into it.  We had to cancel our annual family 4th bash due to the virus running through the county.  Didn’t want to risk people unnecessarily, lots of old people (including my wife and I) in the family.
Marty
Yeah,  according to the risk ratings I'm high risk, (Age and BP)  SWMBO is even higher risk, and my Mom is extremely high risk.
I hit my first YS in 3 months three weeks or so ago.  Everyone was cool and playing safe.
Last Sat it was a bit looser, but still reasonable (No Yard Sales worth trying in the gap...)
Sun I hit ONE, and the people doing it had no masks, one "shopper" had a mask and the other didn't.  then a carload came in - No masks and crowding past...  I left, FAST!
So as painful as it is for me, I'm again done with garage/yard/estate sales (maybe if they state; "Masks Required" or other indicators of sanity), until this blows over.  I hate paying Eprey prices, but better to cherry pick and maybe fill hard to fill gaps for a while...
Scouterjan
Super nice stove Marty
campknot
My mistake, the brass cased stove is a model #9 but is very similiar to a #3. Here's a link to the previous postings with pics.
https://www.colemancollectorsforum.com/post/help-with-newold-kampkook-9-stove-5967118
Very cool No. 9 campknot!  I'm amazed it had the Mod 9 as I believe the 9x is a bit bigger than the 3, and yours is the same as a 3, only brass!
So begins the hunt!
Linking your pic here:
[kampkookno9002]
And that unique pump: [kampkookno9029]
So I did get the KK mod 99 down today finally...
Certainly the smallest 3 burner I have.  Only  10-1/2 X 26 X 4-1/2 - The No 3 is 8-1/2 X 14-1/2 X 3-1/2 X, so a bit bigger, but compared to a 426...
It definitely needs work - Tank seems good so far.  Cleaning it with Greaz-off, is taking the "brown stuff" off the tank.  I can't cal it paint as I've never seen Greaz-off touch paint.  It did show a hint of a maroon paint and the remnants of a label.  Not sure Its salvageable...  Is maroon or burgundy the original color for these tanks?
I'll need to make a new wind baffle keeper wire for the right side and fix the right side lid hinge (metal just broke in two), and repair the bottom where the cast iron burner bolts in as that section rusted and completely broke free... Again on the right side. Hmm... all the abuse seems to have been on that right side...
Before Pics:
Open, its a bit rough:
The Busted right hinge
Right side keeper is there but the bracket needs spot welded:
Right side Wind screen keeper is MIA  -should be an easy one to reproduce, I have the steel rod already:
The broken/rusted out right burner mount - this will need a patch, and I'll probably just solder it in
See the little kink to the left of the latch?  these are easily removed with a special set of tongs I made,  one pair 2" wide for small spots like this, and another 4" wide for larger flanges.
Once the burner is out of the case,  I'll use the larger tongs on this ledge.  there are a couple of places the ledge needs lifted back to 90 degrees...
And the label:  I'll see of Greaz-Off will take this brown crap off and if not, attack it with Simple Green...
MartyJ
Judging from the badge Outlaw, yours certainly looks like a repaint.  I think mine is the original brown.  My tank is I guess what you will call maroon in color with a fairly decent label.  The tank color is the same as the label color on the lid. I think You can see in my first picture.  Wish some one would do repos of the label. Looks like mostly minor issues on the restore and it is a nice size for a 3 burner so I think worth it.
The brass #9 Would be great to have!   I bet there aren’t too many of them.  KampKook sure played fast and furious with their numbering.
Marty
Scouterjan
That 3 burner is cool. From all these I have seen or own early AGM were black then switched over to that olive green color. Early PW were brown. Sure wish there was a good timeline with pictures for these. There appears to be same or very similar models with different model numbers. Confusing as hell. And it's like they had several models in the same time period
Yeah,  this one is showing the light olive color once I got some of the brown crud scrubbed off.  Still working on that, but the grease is off.     I need to get the burner screws out without messing up the thin bottom metal on the left end, then work on the screws on the right.   I posted a WTB in classifieds for a burner ring as one didn't survive the USC...  just eaten away too much.
This one may be a complete strip and paint again.  The tank is for sure.
Does anyone know a good match for the original light olive?    Jan you are right about the black, then light olive.
MartyJ
Outlaw, the print ads for the KK from late 20’s to early 30’s advertise them as “Olive Drab” so I would think an olive drab in flat or satin would work.  Haven’t check the rattle can racks for it.  My # 3  peg leg is black, my #3 wind flaps is Olive Drab and my #10 3 burner is a brown.  I do believe the brown is the origins, color and not a repaint.  If it is, it was a good job.
Marty
I don't recall seeing another 10 besides yours Marty.  This 99 was definitely a light OD liked the later 3's and other early but not 1st gen stoves I've seen pics of.  I'll get a pic of the contrast to the brown "stuff"
StanDahl
 Then there's the #6, which is also a stretched out #3:
#3 & #6 Side by side.
Stan, nice Model 6!
Kind of weird they put the burners so close to the sides?   Th 99 has its first burner a good 1-3/4" more inboard thnn the Model 3.    Yours looks just about the same as the M3?
More on the 99:
So I finally got my camera batteries sorted out - one of 4 (uses 2 at a time) croaked,  and the other 3 are on their last legs.  So time to order 4 more NiMh AA's...
Pics of the OD patch I got exposed.  I'm hitting the burner mounting screws with Kroil now, as they won't budge.
I also spent some time finding a couple of mandrels for un-denting the tube of the pump for the KK Mod/ 99 tank.  Someone used a mallet to knock the wing nut loose (Pump doubles as the fuel fill cap) and had a history of missing.
I used a piece of aluminum tent pole sleeve for stage one (and my lifter pulling tool to get it back out) then the head of a 3/8 X 12" socket extension for stage two, then the same in a vise to tap at it with a small wooden mallet to finish. still looks rough on the outside, but the inside now runs smooth!  Very happy the brass did not crack!
The wing nut wings are still bent and will stay that way.  I don't want those to snap off...
Before:
After - still ugly but the pump runs smooth.
StanDahl
Yeah, I wonder if the #6 has a burner that was also used in a larger stove and they stuck it in this case. I have access to some 1930's AGM parts catalogs that give clues to which models are related to what, but they don't mention a #6, or anything with the peg legs. Examples of those grouped together in 1930: 4, 7, 8, 10, 12, & 14; and 77, 88 & 99. The #1 and #3 are listed separately.
Stan,  any chance of scanning some of those catalogs?  I'm guessing the 77, 88 & 99 were all cast iron grates?  But wait; Marty's 10 had a CI grate also...
StanDahl
They are not my catalogs, I don't have permission to share.
Understood,  NP!
MartyJ
The peg leg #3 appear in all the early 20’s ads and then seem to drop off.  They are definitely not as handy as those with wind guards in the breeze.   I see some ads with the #3 in both styles.  They are a little pricey but I’ve started buying original ads that match these stoves so I have some documentation as to years made.  They look good displayed next to them too.
Outlaw, I saw a 1925 ad showing a #4 that appears to have that cast iron grate.  I also found an add dated 1920 showing the #3 peg leg.   It is out of a Motor Tourist magazine.  I bought that one and will show you next time we can get together.
Marty
Scouterjan
Trying to get a timeline for these is crazy. It makes me wonder if some years they had several models in production one of mine which looks similar to an early Coleman with the solid top and cast burner rings was so poorly stamped I called it the wrong model number for years IMG_20191110_49577.jpg  IMG_20191110_18460.jpg
Wow,  that's THREE styles for the Mod.3...  I wonder if its a Franken Stove?
I got 2 of 4 of the burner mount screws out of the 99.  the other two are sneering at me..
Heat,  Kroil, More heat and Kroil,  a couple of days in Evaporust,  More Heat and Kroil,  a Hammer impact (can't go TOO hard or I'll snap the CI foot...)
I'll have ot grind the heads off and drill/Tap..   #12-24 so not TOO weird a thread,  finding screws?  not so fun  I need 4 12-24 Truss heads.  easy to find - IN BULK...
