Kmot
I have another project added to my list. This is a Jetson's era profane fuel lantern. Made by Turner, this version was sold by MW.
It's in pretty good condition. I will de-rust the frame and burner tube and then give it a fresh coat of hi-temp silver paint.
I think the hardest part of this project will be finding the long and thin propane cylinders.
So far I have scrubbed the frame and burner tube with Scotchbrite and fixed the bent valve handle. Click image for larger version - Name: res4627.jpg, Views: 1494, Size: 174.71 KB Click image for larger version - Name: res4629.jpg, Views: 1502, Size: 104.71 KB
Click image for larger version - Name: res4631.jpg, Views: 1487, Size: 128.60 KB Click image for larger version - Name: res4633.jpg, Views: 1479, Size: 100.34 KB Click image for larger version - Name: res4634.jpg, Views: 1484, Size: 144.96 KB Click image for larger version - Name: res4635.jpg, Views: 1474, Size: 120.96 KB Click image for larger version - Name: res4636.jpg, Views: 1467, Size: 135.22 KB Click image for larger version - Name: res4637.jpg, Views: 1454, Size: 75.30 KB Click image for larger version - Name: res4638.jpg, Views: 1461, Size: 141.24 KB
~Tom~
Coleman 275 Appreciation Syndicate Member #0017
ICCC #1274
joneal
Looks like the propane cylinders sold for propane torches would fit. That could be a source.
Jack
Cool lantern Tom! Very retro looking and appears to be in beautiful condition. The slender blue propane tank might work for you.
Looks like your table is either getting smaller or you collection is getting bigger! Hmmmm....
Just looked a little closer at one of your pixs. Are you becoming a stove also?!
lanternman
Tom I have a lantern just like yours. You can get the propane cylinders at Your local walmart. It's the same as the ones used for plumbing. About any hardware store will carry them. I think they are really cool looking lanterns.
Steve- ICCC Member # 1244 Albertville, Alabama
Lanternman
Kmot
Thanks guys! Glad to know the cylinders are still around.
Mark, I am a poquito stovie. [tongue]
~Tom~
ICCC #1274
LanternTom
Where did u get that? Its cool.
Tom Reis
"Light 'em if you got 'em!!
ICCC# 1303
Kmot
Found it on the auction site. [smile]
~Tom~
ICCC #1274
Scouterjan
Tom, that is just too cool, thats 1 propane that should not be hidden a corner, SHOW IT OFF
GasPrescue
Neat find. I am sure you are going to sweat your ba!!s off on that one! [Rest]  [smile]
This member has passed on: 1959 ~~ 2017
Glenn
GASPRESCUE
____________________________________________________________
If you think you can or if you think you cannot, you are correct
Kmot
Evapo-Rust worked its magic. What you see now is just flash rusting. I will steel wool that off, prime and paint the frame when it warms up outside.
~Tom~
ICCC #1274
adelcoro
Nice!!!
ICCC 957
Kmot
Thanks!
Okay, I steel wool'd the flash rust off the frame, primed it, and painted it with high temp silver. I will let the silver dry overnight before I handle it.
And I also used some Meguiar's polish to try to remove the staining from the painted body. The stickers are paper, not coated so I had to be extra careful to not get any chemical on them.
~Tom~
ICCC #1274
I have one just like it, and it is a Turner.
Uses plumber's propane torch cylinders.
Bruce Sheehe
Kmot
So the next day, after letting the frame dry overnight, it was bright and sunny and I could see I missed a whole lot of area! So I had to spray it again and let it dry overnight once more.
Today I put the lantern back together. Once I get a correct propane cylinder for it I will install a mantle and take a money shot. [smile]
~Tom~
ICCC #1274
Kmot
I went to my local OSH and found they had nice Bernzomatic cylinders in the perfect size. [smile]
So here it is before the first boom:
After I figured out how to get it going, it works quite well. Not as bright as any of my Coleman CF lamps though. This air bleed is the key to get this lamp burning correctly and the adjustment is quite critical:
So here is the first light up, and the obligatory tree and fence shots. [tongue]
And just some miscellany:
I think George Jetson would approve. [biggrin]
~Tom~
ICCC #1274
OldBlackCat
good clean up tom!
Justin
Severance, Colorado
Mission Hills, CA Los Angeles County (escaped)
Coleman 275 Appreciation Syndicate, Member #0030
HillCountry
Excellent work and photos Tom! It looks like something the Jetsons would take camping!
Tim - ICCC Member #1217
Cole_Man420
that look's like it came out of the box!!  good job tom!!
*My lantern habits has participated 15% or more in Global-Warming* The Coleman Blue's 243's.Founder#001. Globe Collectors Club#002. Coleman 275 Appreciation Syndicate#0090.
It looks great, Tom!  I've been watching for one of those for a year, and don't
remember seeing any that look that good.  Nice work!
kurtruk
I thought this was pretty cool, but passed on it.  Being new here, and it being propane,well...you know peer pressure.  DANG!  Wish I'd bought it.  I thought it was just so funky.  BTW  It's Western Field, which is also Monkey Wards, right?
"I want my two dollars!" -paperboy, Better Off Dead
"One would be wise not to believe all the quotes you read on the Internet." --Abraham Lincoln
Traveling Lantern Host #5
IDITOS# BR-549
Kurt
Kmot
Kurt, yes Western Field is Monkey Wards brand. I believe what you passed up was the first generation Turner propane camp lamp.
~Tom~
ICCC #1274
Those are cool! Someday I will find one.....
mgmlvks
Wonderful!  I need the globe for mine as the one it was shipped with is now taped together!
Francis Bacon
Kmot
Mike, Do you think there is a Coleman lantern with the same size and taper of globe? Finding an original made for Turner might be tough.
~Tom~
ICCC #1274
The globe looks similar in size to a 5107 Coleman style.  I don't know that
it is, but it does look much like it.
mgmlvks
I have revisited my turner - Globe still broken and taped up!  When it happened - a long time ago - I could not match up any of the Coleman sizes - but as I know more now and have more Coleman Friends (here!) - maybe there is a replacement out there.
Size is below - perhaps could go 1/8" larger diameter if necessary
height - 4"
Top - 4-1/8" Diameter
Bottom - 3" Diameter
Francis Bacon
JimDouglasJr
There's a lot of globes on ebay with one of these right now.  I'll PM it to you.  You can always sell off the rest as individuals, usually for more than you paid for them as a group.
Great mid-century color and design. Would not look out of place on an Eames table.
abush
Hey measurements of my globe I got were using a tape measure and calipers:
Top: 4 3/8" | 113mm
Bottom: 3" | 77mm
Height: 4" | 102mm
BernzOmatic Appreciation Club #054
Bowzer
I have one also ,Turner brand, they are cool!!
Jim wil ox
abush
I have 2 of these. The one pictured was unfired, VHT coated burner frame  and clear coated the stand. I then put valve assembly of a inert red canister. Strange thing is that the valve assembly (which came from another turner lantern) and Frame tube did not align. I had to shim with 1/8 copper washers.  It seems the Frame tube was longer than my other lantern.  Or the valve fuel tube should have been shorter.  I decided since it was pristine to zip tie some wire and put a bulb in it for daily use much to wife's dismay.
Does anyone know if they may have differing valve assemblies for these to explain the non- alignment?  Or perhaps this was the reason it was never fired? defect right from factory.
Inky Ford
I have a Turner and wonder if anyone has original instructions.  Mine has a knurled nut (red arrow) that covers the air inlet orifices.  I am wondering how these should be adjusted in combination with the main gas valve.
Always on the lookout for propane lantern oddities.  DM me if you have something for sale.
BernzOmatic Appreciation Club #211
http://www.metalcombworks.com
abush
I usually just adjust mine for air/fuel ratio to get the brightest glow. Also there should be a spring in that area to provide some tension so the air flow adjuster nut doesn't move on its own.  My spring was missing on one of mine and went to local HW store and found one close enough in dia and cut to length.
Inky Ford
Thanks for that information.  Do you have a photo of the spring set-up you can share?  I am not seeing the spring in any of the photos I find of this type of lantern.  Sounds like a good idea.
abush
sure its only about an inch long puts a bit of tension on ring
Inky Ford
Thanks for the image.  It looks like we have different fitting configurations. My brass knurled nut is used to secure the propane assembly to the lamps gas tube.  The silver steel knurled nut on my unit is what is used to regulate the air.  On yours it appears that larger silver knurled nut makes the connection and the brass is for air regulation.  Am I seeing that right on your lantern?
abush
Yes. Interesting. I believe that may answer an early post of mine. It looks like they may have made slightly differing valve/lantern configurations at some time.
I have 3 of these lanterns but only 2 valve assemblies. My valves didn't align perfectly with one of my lanterns that I shimmed with 1/8 washer to align.
So in your case you may not need tension from a spring to hold the adjusting ring in place.
Inky Ford
I had a slight alignment problem with mine as well.  The fitting on the bottle (and most bottles these days) is not perpendicular to the axis so I had to over tighten it a bit to get a better angle.
Have you made a case for yours?  I am thinking to make something in this shape like an old sewing machine case.
Inky Ford
height - 4"
My globe is about the same dimensions with the top diameter being closer to 4 1/2":
abush
I bought one from greatglas@greatglas.com from Berkley Cone, it was not cheap.  $95  I gave them this measurement and drawing. But I needed a globe. It was a perfect fit.
Top  OD 4 3/8" or 111.12mm
Bottom: OD 3" or 76.2mm
Height 4" or 101.6mm
Inky Ford
Top  OD 4 1/8" or 104.775mm
Bottom: OD 3" or 76.199mm
Wall 2 or 3mm is fine
In an earlier post you mentioned a top OD of 4 3/8". Please confirm that your replacement is 4 1/8". Would a globe with a 4 1/2" top OD fit your lantern? Thanks!
abush
Yes you were right I second guessed myself  when I saw the 4 1/8 post earlier.  I went out and measured  4 3/8  is spot on. I do believe it would be ok if it was 4 1/2 on top seems to be a bit of room to spare
Inky Ford
@abush thanks for all the great information. I may look into having a few of those globes made up.
