Northman49
Sometimes your only solution is a lead washer. I purchased this kit from A-Zon. It can punch a variety of sizes and has a centering pin. So I decided to try some.
  To start I got some fishing sinkers. Melted them with a torch. While still warm hammered it to about 1/8".
  Then I used the 1" inch punch followed by the 5/8" punch and came out with this. IMG_4011__1599672973_86966.jpg
Comments on the punch set.
  Reasonable price and quite solid. I think when you punch out the inner diameter the process slightly increases the outer ring by a bit. It is not very easy to center the pin on your second (inner) punch as the pin does not protrude very much ...but it can be done. Mine was not perfect...but I have learned.
   I could also use this to make pump leathers.
  There are more expensive kits out there that will do the inner/outer in one shot.....but not cheap.
                 ICCC no.1880
                 CANADIAN BLUES Member #023
                  Mil-spec ops #1982
Nice kit with pretty decent results, Ed.  I've got a whole bunch of lead here, but only one lantern that uses lead washers, and I bought those already.
Northman49
I think fishing sinkers are pretty much pure lead.
                 ICCC no.1880
                  Mil-spec ops #1982
you can also buy proper lead gaskets .  https://www.oldcolemanparts.com/product.php?productid=3546&cat=&page=1
The so-called "centering" punch set like that that I bought had a center pin so sloppy there was no way to make a concentric gasket with it.
I broke down and bought an expensive set made by Mayhew (or someone in France). It can mount up to three sizes, making gaskets that are truly concentric in one punch.
[48810786766_8a39f3a8ac_b]
Set up here to make a cap gasket and a pip for... well, I forget.
These are also very sharp and good quality steel, so they should last a while.
I should note that punching a bunch of holes at once takes some force. I use a 1 lb hammer and a goodly swing on a plastic cutting board, set on the concrete floor. It also helps a lot to spray the punches down with silicone spray every few uses.
I was thinking about casting some lead gaskets for the Aida lantern because I wanted to remove the torch and clean the pickup screen. I 'd buy more from Brite-Lyt but the shipping is more than the parts, so I was thinking about making a mold in some plaster of paris and pouring from my lead pot. Hmmm....
https://www.rotometals.com/sheet-lead-1-8-8-lb-sq-ft-1-x-1/?gclid=EAIaIQobChMIl7jD9Ofc6wIVYRitBh1QrgLTEAQYASABEgJIbPD_BwE
pitmanmarine on eBay sells them and shipping is not bad. Once there get some cleaning needles and he will adjust shipping.
“Solo sé que no sé nada”
