paulbarrette
Sounds like an mma move, but if one side of missing the lock nub you can't stand the stove on the legs safely.  Any ideas to fix it?  I was thinking maybe a pop rivet?
Note the let side is missing.
Thanks
Pb
[image]
Paul Barrette
Barrett
Hi Paul
I think a long enough pop rivet will work, or a small bolt and thin not that fit between the lock spring bar and case?
Andrew
Living and learning in NZ
Barrett
^^Nut^^ not Not lol
Andrew
paulbarrette
Barrett wrote:
Hi Paul
Hi Andrew,
I will try the nut(aka not) job first.  It is easier to remove.  I think the pop rivet might wobble.  But better than nothing.
Thanks
Pb
Paul Barrette
paulbarrette
The rivet didn't work out but the bolt worked well.
[image]
[image]
This works for me.  Note the cars it sanded print for paint.  I figured I would handle the structural stuff first.
Great idea Andrew!
Thanks
Pb
Paul Barrette
Barrett
Yep that would work for me too Paul 🙂
I might just use a file to round off the end just a bit, l'd have a habit of catching my knuckles on it otherwise lol
Andrew
paulbarrette
Sounds good.  I will do that too.
Thanks
Pb
Paul Barrette
