btunheim
Not a fan of the sketchy match up through the hole technique.
The flint coleman igniters are unpredictable.
Anyone have better techniques?  Long matches?
I'm thinking of using a piezoelectric with wires that run up under the mantles. on my  powerhouse 290s. Not pretty but functional?
Open to ideas and ridicule.
Bodi Tunheim
Crater Eddie
I salvaged the Piezo from an empty bbq lighter, mounted a knob on each end.  The wires were already long enough to go through the hole and up to the mantles.  I rarely use matches any more.  I use it to light my stoves too.
Dvan95
Small butane torches work great and you won't burn your hands lighting a stubborn lantern like you would with a regular Bic lighter. I use that or else I use a Zippo lighter but I also typically take the vent and globe off in case it flares up so I have less cleaning to do after.
-Dan
Coleman Quick Lite Crew #048
On instant lighting lanterns I open 1/4 turn till it spits, then flick a bic. On quicklites I use my butane torch through the Mica to preheat the gen maybe ten seconds if that, then crack the valve.
Here's my torch I use
https://www.amazon.com/gp/aw/d/B07RKVHJH6?psc=1&ref=ppx_pop_mob_b_asin_title
Tigerfans2
I use a bernzomatic flexible butane.
Get it spittin good, turn it off and stick the torch to it
Coleman Slant Saver #58
Coleman Quick Lite Crew #8
Coleman Blues 243's #16
I generally just remove the vent and globe to light.  For lanterns that like to flare up upon lighting, it keeps the globe clean.
arizonacamper
I take the vent and globe off strike a match preheat the Genny just a little bit crack the valve and poof lights right up with no drama.
Lanterns are like tools.
I use the same one. But I give the generator a little pre heat every on the newer ones. Then I open the fuel. No fire balls or pops that blow out mantles.
Works for me.
The DollarTree store has Bic looking lighters with a ~1.5" snout that fits in the lantern frame lighting hole ok. They are at the checkout lane with the other regular lighters. They are not refillable.
I use a Bic lighter as well.  To light a propane torch.  After I remove the vent and globe.  That’s just me.  😄
btunheim
Thanks for the advice.
I didn't know about preheating the generator.
I thought I was the only one who removed the globe and ventilator.  Anyone permanently attach a piezo lantern?
Bodi Tunheim
Rustytank
I use whatever is handy
TSPORT
Ditto on removing the vent and globe.  I think the whole process of getting the lantern ready to light adds to the fun of having these GPAs.  Unless it was something I used very often, having an electric ignition method detracts from the nostalgia of the hobby. Just my 2 cents 😊.  On another note, the flint sparkers I had on a few lanterns worked pretty well for me.
Greazy
I use the flint sparkies on all of my lanterns except kero's and QL's. On my mil-specs too. No issues here.
I'm in the butane torch camp
I'm in the same camp as Rustytank. I use what ever is handy. A match, a lighter, sparkers... I have even used thin burning sticks from a fire.
