Hi all;
I don't usually do any work on Sundays, but this piece had been sitting around for a while with instructions from Mike (mgmlvks) to see if I could fix it up when I had some spare time.  It is a little fuel filler cap from a 242, and whomever had it before Mike used "special" knurl-removing pliers to tighten it or loosen it, as the case may be.
[49731561823_030519a4d7_z]
So, yuk, huh?
I told him I would try to figure out something, but just re-knurling it presented the problem of crushing the fuel cap.  Knurling is a very high pressure process, and the fuel cap is thin walled.
Here's my one hour SOnday solution:
Gently chucked up and turned off as much of the old pliers marks as possible without cutting clear through into the inside threads.
I knurled up a piece of 3/4" brass stock for the next step.  Forgot to take a pic of the actual knurling, but here is the result.
Drilled a starter hole in the knurled end and then bored it out to be just a bit of a push fit with the turned down fuel cap.  A push fit is just what it sounds like:  You have to put some pressure on the pieces going together, but it is not actually like a press fit, which is a hard press.  On this one I cut it so I could just barely push the fuel cap into the knurled piece by hand.  Just short of a hard interference fit.  A hard press fit would have likely split the knurled piece, ruining the work.
The trial fit.  At this point it's starting to get stuck, so I pulled it back out  in order to be able to part off the knurled piece.
And there we go.  The piece parted off.  I went at this very slowly, as sometimes parting thin walled sections will end up crushing the piece being parted due to tool pressure.
And the finished result.  I used just a bit of Locktite to augment the push fit so there will be no coming loose.
Hope this works well for you, Mike.  I'll mail it next time I get to the PO.
Thanks for having a look,
Leviticus Tomethreus
     Holy crap that’s impressive
if they did call me that.
Tigerfans2
Building Karma every day👍
BUT...do you have proof it was a PO? Guys in NE Kansas can be pretty ham handed...
Coleman Slant Saver #58
Coleman Quick Lite Crew #8
Coleman Blues 243's #16
Newfie
Great work Dean. You're quite the craftsman.
I'd rather think that Mike in Leavenworth didn't do the pliers deed.  It's just too horrible to think of.  Besides, they looked like very old injuries.  🙂
Tigerfans2
Waiting for the other Mike's input I am..😎
sbh801
A Master at your craft!!!!!!!!!!![sSig_youtheman][bravo]
Shine on!! Steven
austin65uri
Awesome!  Forgive my ignorance, but by what means do you actually create the knurling.?
Bill.
ICCC#1601
Wow! That came out amazing, Dean. Very nice work, sir!
Nice job, I wish I had the skills and tools 🛠
“Solo sé que no sé nada”
Bob1774
Wow, Dean!  Always amazed at your talent.  I only wonder how many folks there are left in our country that can do that sort of work?  You are a true master!
Really like learning bits and pieces from you Dean. Thanks.
Smudge
That's fascinating, seeing the things you do.
coleman54
Very impressive Dean !
Larry
Inquiring Minds Want To Know
Kansas John
I could be wrong, but I think that cap came to me like Dean got it from Mike.  It came off a 242nl with a compromised fount.  SteveRetherford eventually ended up with useable upper parts last fall/winter.
long story short, I sold the lantern and the new owner didn’t want the beat up cap so I switched it out.  It was found the fount was bad.  I bought it back and parted it out.  Mike asked after boogered 242 caps for a project so this ended up with him.
John M. Lawrence, KS
ICCC #1431
warren
Wow!
ANTIQUESWV on Ebay
#1 in the 223B club
Gatlinburg, TN
I'm working in the shop right now, but I'll get a pic of the knurler this evening.  Once you see it you'll get how it works.
Thanks all for the kind replies.
Kansas John, thanks for the story of the fuel filler cap.  Kind of brings the story full circle.  👍
Hey! I happen to have a pair of those pliers around here somewheres! Didn't know they was all that special.
Pretty impressive lathe work, Dean! A fellow would have to look pretty close to know that isn't one piece.
I didn't realize that knurling was impressed, if it is. I always assumed it was cut, but have never seen the process.
Vintageish
Applause!
Well done.
Being way out of my wheelhouse , it's great to see your process.
Nice work Dean! Makes me want to update our old turret lathe that we like to call "Galloping Gurdy" actually sounds like a team of horses running by...
All hail Deanofid!!!
https://www.colemancollectorsforum.com/post/all-hail-to-deanofid-10511570?pid=1311425387&highlight=all+hail
the MASTER at work !!! its very enjoying see what you can Do Dean .
ya some of those 242 parts are here , helped me finish up a NL , thanks again John ...... i have something i have kinda been wanting to see if Dean can fix , but its more of his soldering skills than machine work , not sure its worthy ....
mgmlvks
WOW!  Just WOW!  This was more an experiment than anything else - and Dean comes through AWESOMELY as always.  I hate throwing away parts as each one is one less for all of us.  I believe there are repro 242 sized caps out there - and maybe this is more a re-manufactured cap.  I was just trying to find a way to make them live again - pretty sure this is NOT cost effective at this time - but in a few years?  Who Knows.
Thanks Dean and John for making this possible.  And I admit I have pliered a few things in my time, but GPA's and CCF have taught me new skills including patience!
Francis Bacon
Bill (austin65), here are a couple of pics of one of my knurlers.
This one is a scissors type.  One wheel has teeth angled in one direction and the other in the opposite direction.  This is how diamond knurls are made.  There are also wheels that are just straight teeth, like the kind used to make 242 ball nuts.  I have a few different knurlers.
The round stock is held in the chuck and as the chuck spins the knurlers are tightened down on the stock.
Timm, it's a forming process, called "upsetting".  The material is actually squeezed up out of the surface of parent stock.  When you knurl something in this way, the diameter of the stock get larger.  In some assemblies knurling is used to make a diameter larger for a hard press on interference fits to hold parts together basically forever.
Bumpkin 95
Very nice work. One Sign of a good craftsman is you cannot tell what he did when he’s done. (Meaning it looks new).Pretty much describes the job you done there.
  • Lee
  • ICCC member #1927
Nice work Dean. I wish that I had skills like that. I wouldn't know where to begin.
GoCamping
Always a pleasure to see what Dean can create and or bring back to full operation again.  Very good special talents at work!
Chris
Looking for any Lantern dated "10-89" (B/D lantern for my Son)
mudbox
Whoa.  I wish I had your skill (and tooling).  👍
-Jason
Milspec Ops #1978
275 Syndicate #228
Quicklite Crew #49
Wirefox
Very impressive, Nice work Dean!
Vance     ICCC #1538
Coleman Blues #151
Coleman Quick Lite Crew #14
austin65uri
Knurling.  Thank you Dean; very interesting and informative.
Bill.
ICCC#1601
mgmlvks
Some knurling videos on youtube - none as good as Deans pics - but this one gives a sense of the operation - start about 7 minutes to miss the set-up.  Watch at higher speed does not hurt !  Delete the spaces between // and you to get the vid, or for most folk just click on the 2nd part below.
https://      youtu.be/38fo1R28t4E?t=424
Francis Bacon
Banjoman
I’d do it just like that Dean if I had ur skills. Excellenta!
Banjoman
Bob1774
Let's just end this thread with, "Dean, you the man!"
gotac65
Now that i see the knurling wheels it makes perfect sense.
Awesome job!
ICCC# 1740
Mable and Jasper's
Beauty Parlor & Chainsaw Repair
We can fix anything!
mnhogrider
A fuel cap retread! Great work Dean!
ICCC Member #1396
Mack, Cat and Cadillac.
smarti
Wow!!! I am glad I have my place in line. That is absolutely amazing.
Scott
It was Love at first light!!! Scott
 Very cool to see the process.  Like much fabrication that is rework, just having an idea of the processes available to meet an end goal sets the craftsman apart from the master.  Well done Dean.
That is very nice, Dean, looks great! I, too, wish I had skills like that.
Duck
I like it! I never knew how they knurled stuff but seeing that tool now clears things up for me.
Mike said,
Dean said,
I’m not anything near a machinist nor could I ever have hope to have half Deans skills so I m asking this Just for some knowledge. Could you have threaded the brass rod and screwed the cap on there and reknurled it or would the cap still deform or become to thing to be trustworthy?
Mil-SpecOps #0219
Stovie and Damn proud of it
how long does one have to be dead before it’s considered archeology  and not grave robbery?
Hi Joe;
Mike and I talked about trying something like that, but the cap was so chewed up it wasn't even all around.  I don't think the knurls would have looked good at all.  Also, once it gets just so thin, the knurler would start to deform the inside of the piece.  It might not come off the threaded piece that the cap was screwed onto at all.
monkeyboy
this thread has legs.
anyway suffice it to say, those little 242 fuel caps are pretty cool. i have small hands so they feel good to me and to save one is pretty darn awesome.
skilled Deano certainly is.
buzz
buzz the universe in a drop of water Coleman 275 Appreciation Syndicate Member #0066
Mudzoory
Awesome work!
Coleman Slant Saver #50
Coleman Quick-Lite Crew #18
MYN
That was a great job done. Another piece saved. The piece is still original. Wished I have these machining skills and a workshop with all the necessary toolings to do this myself.
I've had some brass nuts turned out and knurled in a machine shop before. Yes, its certainly a high pressure process and would certainly deform the original filler cap if it was re-knurled directly. Like Dean hinted, the inner threads would have been messed up too.
Deanofid wrote:
Hi Joe;
Hi Dean,  Great work!
I was going to ask the same Q Joe did, but I would have suggested a steel mandrel for the support core.  I've never tried knurling brass over a marred up surface that I can recall though (For a while I was knurling EVERYTHING... even my dads old reloading press handle - solid steel, no plastic grip...),  and your comment about "will it come off the mandrel" is a good point.
Maybe with a hardwood cap fixture like was discussed in another thread for gasket removal would make it doable?
Duck
That’s what I thought Dean but I had to ask. Now Mike needs to send it to Timm and get it nickeled
Mil-SpecOps #0219
MartyJ
You sir, are a magician!  Nothing less then magic could accomplish that.
Marty
Nighthawk
Nicely done!
ICCC#1860
Coleman Slant Savers. #46
The Coleman Blues  243's. #152
Milspec Syndicate #0333
Coleman Quick Lite Crew #11
mcdugal2
We have a three pattern knurler here, but we can't use it because it doesn't fit the lantern on our lathe it would need to be cut down even more than it already is...
Phil Rhoades ICCC# 1125
Those three pattern knurlers are generally left to heavy lathes, since they put a lot of stress on spindle bearings in the lathe head stock and on the lead screw in the cross slide.  I don't know how large your lathe is, but if it is quite large, making a tool post for it to hold the three-way would be the best bet.
