joe mott
heres my lamp i talked with yas about, i was thrilled to see the guy had found the shade, does it look original? it is missing the pump as you guys noted, is it a hard to find item? thanks so much for the help fellas
Rouses Point NY
Nice lamp, Joe.  You are missing the thumb screw that goes into the fill plug.  Someone has substituted a screw.  OCP sells them:
http://www.oldcolemanparts.com/product.php?productid=3547&cat=&page=1
Mike also sells the pumps:
http://www.oldcolemanparts.com/product.php?productid=2334&cat=&page=1
I'm no lamp expert but I think that is called a hobnail shade.  It looks too small to be original. Perhaps from an Aladdin kero lamp.
Barryb
Nice lamp Joe!... Careful, lamps are a slippery slope that I know all about. LOL. Hope to see it burning soon.
ICCC #1565
REJ2
The thumb screw you need has much finer threads than the bolt someone has substituted. The picture I'm showing is from a round filler plug, the hexagon filler plugs also use a fine threaded screw which when I checked seems to be a little shorter in length.
Click image for larger version - Name: 0225181114a-612x816.jpg, Views: 65, Size: 148.22 KB
Bob    ICCC #1574
ya , that screw may have jacked up the threads ? you may need a complete fuel cap ?
joe mott
oooo i see the pump is separate! im learning all the time here lol. thanks a lot guys
Rouses Point NY
joe mott
would this be what i need?
http://www.oldcolemanparts.com/product.php?productid=3871&cat=&page=1
Rouses Point NY
No. Yours is hexagonal and screws into the fuel bung, whereas that round one screws onto the outside of the fuel bung.
I don't see the proper "fuel plug" (Coleman term) for your CQ lamp at OCP, but sending Mike an e-mail might find one for you.
xoleagleye
Joe, the only part you need is the air stem. Unless the threads are messed up by the screw they threaded into the (correct terminology) filler plug. Here is a drawing of the break down of parts for the CQ lamp. Click image for larger version - Name: FC2F0C16-4B81-4473-9EF0-771B3C49F1EB.jpeg, Views: 65, Size: 95.42 KB
joe mott
ok thank you. im going to bring it ibnto work and see if i can save the threds
Rouses Point NY
