Stephan
Ok, please tell a newbie how to clean a generator?
Helps to know for what (stove or lantern model?), but usually you would remove the pricker and unscrew the tip (if removeable).  Soak the parts in solvent or acid.  Polish with steel wool.
What are you looking to do and for what type of GPA?
Stephan
It’s for two of my kerosene lanterns, I don’t think that I preheated them correctly. Not sure what a GPA is?
Smudge
Same instructions(above) for kerosene. I also use extra rigid bristle pipe cleaners with solvent to clean inside the generator tube. GPA = gas pressure appliance. Here a link for a glossary of terms:
http://www.colemancollectorsforum.com/post/terminolgy-help-7505821?highlight=glossary&pid=1291169556
philbotha
That is, gas meaning gasoline and not propane or butane.
-Phil
Favourites: 238A B/41, 238B 6/50, Petromax 816 lamp, Petromax 827 lantern, Primus 1020, 1060, 1001, 995 lamp, Radius 108, Optimus 1200, 246B 5/41 241A 5/52, Veritas Gloria lamp 1922, Gloria Oxo-Gas 1913 The Evening Star 1924 lamp, The Evening Star 1922 lantern, Sunflame 104(US), Sunflame 106(UK), Bialaddin 300X,TL10, BR49, PL53,
Stoves: Coleman 425B, Primus 96, 523, 535, Optimus 111, Radius 43, Speedmaster 500 D/38
275 Appreciation Syndicate Member #0181 The only one in Africa?
Coleman Blue's 243's. registration #133 (the fourth known 243K)
