JosephDurham
Is there a difference between the Coleman White Gas and the Crown White Gas?  I have two gallons of the crown and was going to use it tomorrow, but wanted to check. It’s cheaper then the Coleman in my area.
Thanks
Joseph Durham
ICCC #1954
Looking for bday lantern 10/84
Same thing, both Naptha, Coleman has a "rust inhibitor" and is about $4 higher here... If you got it, run it, I say ðŸ‘ðŸ˜
Not enough to make a hill of beans difference, IMO.
Only difference I have found is price...
Toby nailed the difference... about $4.
  Some have expressed concerns that the rust inhibitor may clog things up in older lamps.  Unless you burn gallon after gallon of CF you'll likely never see a difference.  I burn lots of Crown because I'm cheap, but I've run gallons of Coleman fuel that I know went as far as 1971, and it all works just fine.  For that reason, I never pass up the $1 and $2 for full cans of any brand Camp Fuel at thrift stores.  The Champion fuel was $1, because the can was "all icky."
Thrift store score
Outside of price, the only difference I notice is that Coleman fuel has a dye in it.  I feel rather confident that Crown will also have the rust inhibitors, and wouldn't be surprised if Crown were packaging Coleman fuel.  I feel rather certain Coleman isn't refining their own 'white gas'.  🙂
My three sons and I have been using quite a lot of Crown and periodically using the Coleman. The Crown has been working great in our single-burner stoves, two-burner stoves, lanterns and heaters.
JosephDurham
That’s great to hear. I use the crown in my svea and Msr stoves but I wasn’t certain if there was a difference or not.
Thanks guys!
Joseph Durham
ICCC #1954
Gavercronos
There is a noticeable difference in the smell, so there are different hydrocarbons in the fuels. But, if it's marketed as stove and lantern fuel it will be perfectly fine in your stoves and lanterns.
WillCat
Chautauqua County, New York
I'm the guy who noticed Coleman fuel clogging up fiber-packed gens like Q99s and R55s. This isn't while the lantern is running, it's being stored. No 100-year-old fuel valve seals 100%, and that tiny amount of leakage--not enough to smell--is slowly evaporating through the gen tip, leaving greenish deposit at the top of the gen. You can easily flush it out by removing the tip and running some fuel through the gen, but then again, you can't easily do this on a 2-mantle lantern. I now use Crown exclusively in the oldsters.
SteveA
I've been using Crown exclusively since I noticed that Coleman apparently doesn't want to really sell fuel anymore.  They have to be aware of the price difference. I've had no issues with the Crown at all, burns great!
Traime
im sure they are aware of the price difference, but Coleman fuel is THE standard for certain performing arts, at least among all the professionals and teachers I've talked to.
my understanding for this is that Coleman includes the most accurate information in their MSDS, but I'll ask around and double check.
as far as our uses in here though, no noticeable difference I've found beyond price. Crown has been working 100% fine for me.
Rustytank
????? Firebreather or such? Stuntmen in fire scenes???
Certainly the fire breathers.  It used to be documented on Coleman’s site, but good luck finding it.  Their search engine is almost as bad as the one here.
[48997152182_a7c039fdec_b][48996949386_dceb32b962_b]
Poi dancing w/Coleman fuel.
Traime
Fire Eating and vapor play more than Breathing.
personally was taught not to use CF to breathe, much higher risk than other fuels.
@Gunhippie is that you? Would be nice to find some other fire dancers on here. Contemplating making a "party tricks" post
After taking a shot either every morning I can’t tell the difference!
Thank you
I frighten easily!
DougA
Our baton twirling group at school did a routine with fire batons once a school year (homecoming assembly) and the advisor of the group always used Rosonol lighter fluid in the batons, for whatever that is worth.
Coleman Blues Member #92.
@Traime
Nope. I keep my flames behind glass or under a skillet. That's one of our brewers here at the brewery Halloween party last year.
There are probably about a dozen folks locally who are into poi dancing--that I know of. I hate the competition for fuel!
@Whitegas Extraordinaire
Are you mixing with something like orange juice?  Straight up?  Or flaming shots?  🙂
Zulu Kono
That should only  be done by attractive women!
Ever!
This guy prefers Crown fuel for all his fire needs.
[IMG-1227]
MYN
To me, there is no difference. I could get neither of them here.
Rustytank
So what did these traditional fire dancers use before gasoline was invented?
MYN
Probably some resinous pitch and brimstone? What's the stuff used on torches and catapults? Alcohol's certainly has been around for a long time.
JosephDurham
I appreciate everyone’s input. Thanks guys!
Joseph Durham
ICCC #1954
