Leviticus Tomethreus
     So I have countless frames that I have taken the rust off of, but where there was rust looks different from where the original finish is. How do you guys put a finish on the frame/collar.
I just shine it up as best I can and call it a day.  I don't shoot for factory fresh restorations, just nice respectable clean-ups so that that the lantern can look it best for whatever shape I find it.
How do I put this kindly. Screw that. There’s no way for factory fresh?
+1
If you want to look like new buy NOS parts or unfired lanterns ðŸ˜‰ðŸ‘
That’s too expensive. I want to try to find a way to make something old look factory original. A REAL restoration. Making it look brand new.
It can be done... But would not be cost effective on anything you can pick up for a Lincoln bill$
Well dang, let’s atleast here how it’s done. I’m curious.
When there is rust the original plating (whatever that may be) is gone... Also there are pits.. So you would have to smooth the pits out then replate with whatever the factory used... Coleman used a couple different materials if I remember right. @Gunhippie has some good posts on plating recently. Might do some searching on here about it. You might want to do some research on electrolysis while you're at it... You may have a good show and tell project for when you get back to school!!
[QUOTE username=Leviticus Tomethreus userid=7320473 postid=1312644101]That’s too expensive. I want to try to find a way to make something old look factory original. A REAL restoration. Making it look brand new.[/QUOTE
If you want it to look factory new, the sky's the limit on how much you want to spend, how much money you want to invest (and ultimately lose) on it, and how much time you want to devote (or pay someone else to devote) to getting it done.
Any matter or problem can be solved if you throw enough time and money at it.
I think the secret is to start with something that's not real bad to start with.  If there is rust and no pits on a plated collar I can often bronze brush the bare spots that were rusted and get them to blend well with the zinc plated finish.  You can also swap on better parts to replace parts that are flawed.
Trouble there is that you're doing less restoring, and more recreating.
If it looks good lit, in the dark, it's good enough for me.
Gavercronos
You gotta to determine what the original finish was first. Some were nickeled. Some were hot dipped in tin. Some were galvanized. Some almost look aluminized like exhaust pipes. Some were flash chromed. And some were bare steel. Bringing a frame "back" to the wrong finish will not end well. Except for the bare steel, that only takes a lot of time with a buffing wheel...
WillCat
Chautauqua County, New York
Well then what can you do to protect the bare metal
Gavercronos
I generally use linseed oil. Others use clear coat, but that's definitely not something the factory would have used.
WillCat
Re-plating anything is expensive, which is why you are getting the advice you've been getting.  Do a little research on at-home tin plating just to get an idea of what's involved.
If you clean the metal really well, you might look into the VHT spray-on surface sealers, though I don't know if  they work on bare metal. I've never re-finished the frame, though I've thought about powder-coating them silver. No matter how you approach it, it won't be inexpensive.
As @BSAGuy said and is a joke where I work too, especially when a manager stops by and asks, "Can you get this done by this date?", to which we reply, "Well, we can do anything with enough time and money and since that's not a lot of time, we're gonna need a lot money." It holds true more often that you'd initially think.
Well I’ve Jerry rigged a home nickel setup that I’ve been scared to use. My grandpa painted really the majority of his lanterns (Well, the frame and everything inside it) silver. It’s a really rough texture, I actually think it fits the lanterns really well though. However they have been a massive sob to take apart because my Grandpa basically just took the vent and glass out and taped up the fount and globe. He painted with the burner and generator and with the older ones, the tip cleaner assembly too. That was probably 30+ years ago, and they still look great other than some minor rust.
If you just want to keep the rust away and protect the frame from the ravages of time - spray them with VHT Flame Proof Clear coat (as opposed to grandpa's silver paint) and follow the curing directions carefully.
You can then see the patina of the old steel and still have a bit of protection for years to come.
MYN
The area where you've removed the rust will always be different from the original steel and finish. Part of the steel is gone as rust.
The frame was made from pressed sheet steel and not that thick. So you can't just replace the lost metal by means of welding and grinding it back to size.
You can still build up the metal by soldering or brazing, then size it down back to shape and coat it with whatever finish(paint, galvanized, plating or tin coat) it used to have originally. But that's quite a lot of work and can be costly.
An easier alternative would be to build it up with some heat resistant filler or paint primer and then paint it over. If the job is neat, it won't look much different from factory finish.
I would contact  Murff. He might have a few tips or even a vendor.
A vendor? And our lord...   MURFF.
Neither option is cheap but you can have the earlies done in gray Cerakote and the newer ones done in Chromex.
The coatings are thin and the pitting and rust patches will still show will show but the whole frame will be the same color, at least.
Talking about 200A frames here.
For for frames on lanterns that I just want to protect from future rust (which occurs fast here in humid NC) I use VHT flat aluminum (i think this is better than the flat silver). Note that this is not a restore to original - but something that will make the frame last for another decade or more.  First i get rid of all the rust I can using a wire wheel and/or dremel. If there is a lot of rust i use EvapoRust overnight. Then I do an acid bath cleaning (20% muriatic acid, 80% water). Rinse in clean water. Clean quickly with denatured alcohol. Then paint according to instructions.  And it is important to cure the paint. I let the paint dry for an hour them bake at 250 for 30 min, cool down, then 450 for 30 min, then cool down. Then install it on the lantern. And when you first light it - let it run for 15-20 min then shut it off. Let it cool.  It's then ready for the next 10-20 years.
