paulbarrette
Hi all,
I took apart the burners on a 425 stove for cleaning and there is a very delicate felt like fabric gasket between the burner and the pipe manifold. What material is that?  I thought it would be a paper gasket but is much more delicate.
Thanks
Pb
Paul Barrette
A white gasket?  If so, it's most likely asbestos, so just don't play scratch and sniff with it and you'll be fine.
paulbarrette
That is what I suspected.  Is there a substitute?
Pb
Paul Barrette
I think those were on the newer models, so probably fiberglass or mineral wool--not asbestos. Keep it damp if you're worried.
I usually use a little wood stove gasket cement on that join. Keeps that annoying candle flame from under the burner.
paulbarrette
Hi GH,
Great idea.  Saw this stuff at Canadian tire near  by
https://www.canadiantire.ca/en/pdp/imperial-gasket-cement-2-oz-0642721p.html
Thanks
Pb
Paul Barrette
That should do the job. It's also great for sealing a candling suitcase stove gen tip, and fixing those stinky joints in the venturi tube of a 200.
paulbarrette
Good stuff to have in my shop.
Pb
Paul Barrette
