D421
Found another lamp for just a few dollars. After looking the fuel tube was beyond repair.
The pictures show what I have done. Does this look like a fix that will work.
Dominic Click image for larger version - Name: 20200722_124213_copy_567x1008.jpg, Views: 59, Size: 236.40 KB Click image for larger version - Name: 20200722_124234_copy_567x1008.jpg, Views: 60, Size: 94.68 KB
Click image for larger version - Name: 20200722_131739_copy_1008x567.jpg, Views: 58, Size: 146.07 KB
looks like a good repair to me . will the handle and other parts all fit over it like it used to ?
Dominic
I’m a former drip under pressure so consider that first.
Did you cut off the PU and rethread?
Either way, shut the valve pump it up and dunk test it!
Thank you
I frighten easily!
Gavercronos
If the nut that holds the handle down will hold the handle down and still allow the valve to go on, that should work fine. Just seal all the joints up.
WillCat
Chautauqua County, New York
Etch your name in the tubing so 80 years from now, the collector will know who to thank for caring so much for their lamp.
D421
Thanks for the replys.  The handle fits over the splice. The nickle trim had to be opened a little.
Yes I cut the original PU and threaded it.
Sealed with loctite.
Past the dunk test. It's pumped will wait a while to see if it looses pressure.
We will see if I measured right for the nut.
Dominic
D421
I will fire it up later. Pretty happy for 5 bucks.
No initials the fire investigator will have to work harder. Click image for larger version - Name: 20200722_185657_copy_1008x567.jpg, Views: 58, Size: 106.93 KB
Like it never had an issue.  Nice work.
not sure i understand , the pick up tube is not intended to come out of these . its soldered in place from the factory ???? that whole riser and pick up are one piece .
Mister Wilson
Looks good!  For $5 you got a nice lamp and a new skill.
D421
  • I did not remove the anything from the fount. The top threads were damaged. So I cut off the damaged threads and rethreaded the top of the PU tube. Then used a coupler and a short nipple to bring it back to the right height.
gotchya , nice work !!!
Sweet fix. Hope it holds.
Well done! I hope you used a fairly high-melting-point solder for that. That part doesn't usually get too hot, but.... Did you mention the fire inspector?
D421
No solder just not threads. Been running about an hour. No bad result yet. Fingers crossed. This will be an outside lamp. Click image for larger version - Name: 20200722_204216_copy_1008x567.jpg, Views: 53, Size: 209.61 KB
D421
NPT threads. Darn spell check.
D421
Glad I did this outside. The shade holder was painted with some low temp paint. Smokes for 30 minutes.
Nice fix, nice lamp!
SteveA
Great fix!  I've got to get off my butt and find some small NPT taps and dies.
Nice work.
