red green
Not my first restored lantern but my first one posted here.
No before pic, pretty much the same just add a little grime and subtract the mantles.
Wanted to thank OCP and all the folks whose past posts I searched out for advise and info.
Major problems with it when I acquired it were an air leak at the fuel cap and fuel leaking from the valve stem.  (Always test outside first!)  Disassembled.  Cleaned.  Installed new fuel cap seal and tightened the valve packing.  These are almost an exact copy of a 220E.  I actually threaded a spare 220E burner tube assembly in place to see if the threads were the same (yes).  Verified that a 220 generator will fit and work however you must have/reuse the original Japanese generator nut as the threads are different.  I did have to make a new longer vent stud out of 14-20 threaded rod.  Threw on a couple of #21 quick clip testers and it runs fine.
Any ideas on who might be able to reproduce a sticker?
413F&G, 200A, 220C, 228C, 220E, 228F, the 288 twins, Roddy, Ash Flash(s), and just a few others.....
Trout
Nice.  Is the globe original?
I haven't seen a DuraCamp lantern in person but I have a 733 stove that is almost a duplicate to the 413E with a round tank.
ICCC 1473
red green
Its a Coleman (made in USA replacement globe) that came with the lantern when I acquired it.  From what I have read here on the forum, the original globes are very delicate.
As far as I can tell, save the globe and possibly the generator, everything else on the lantern is original.  They really copied the 220.  I had a 220E disassembled at the same time and think most of the Coleman parts would fit right in place.  Most of the threads are the same too.
I didn't know they made stoves also.  Another thing to keep my eye out for.
RG
Stove are brown with a yellow tank IIRC.  Copies of the same Coleman 2 burner.  Japan was very good at US knock offs in the 60's.  Made by Rinnai.
Trout
Like this.
ICCC 1473
Mister Wilson
You'll need the single mantle also.  Quite similar to a 200A.  My son has one, thought I had a picture, but no.
Graeagle Coleman
Single and double Click image for larger version - Name: 90699080-D091-401B-98C6-F3F494B17C86.jpeg, Views: 246, Size: 589.45 KB
Turd Appreciation Syndicate #0210
Jagref
If you find a new Dura Camp sticker let me know as I need one also.
James Jaggers
Louisville, Ky
ICCC #1774
If you light a lantern for another, it will also brighten your own way.
Nichiren
red green
Had some further adventures on the second long run.  Seems the original valve packing gave up the ghost and further tightening did not work.
Went the teflon plumbing packing pieces with gaps staggered method.  Ended up with about nine small pieces by the time I added, tightened, tested, and added more.
Phat_Daddy35
I love the Dura Camps. I have about 8 of the single mantles and 3 of the doubles and 3 stoves, They were also made under the Camplete name. I have a few of those as well. Camplete made a stove which I have one and have never seen another one.
I lost my computer with all my photos but when I take more I'll post them.
The decals are impossible to find I had some made by a local sign shop but they came out darker than the original.
If you find original glass protect it they break easy because they are much thinner.
Chad
As my good friend Tom says " I'll leave the light on for you" (242 in my case)
Coleman 275 Appreciation Syndicate member #3535
MilSpec Ops #0350
Paddywonka
Manufactured by Tanaka MokTanaka Mokuzai Kogyo Co., Ltd. Tokyo Japan. Only reason I know this is my son came to visit and he exclailed "that's a
Tanaka Mokuzai Kogyo Co. Lantern!''
