namacinnis
My husband has his dad's old Coleman Propane camp stove and it's missing the regulator hose. The model is 5424 B701. On the inside lid it says approved for use with regulator assembly model 5415 a 5561 and that it can use an adaptor 5415 7901. (but not needed). This is a very old stove, I'm guessing late 70's maybe 80's but in great shape. We gave the hose to someone to fix and /or find a replacement and they have lost it. His dad passed on yrs ago and he is devastated that he won't be able to use it.  Also, On the hose it said Gates 3220 type 1 , 350 psi, 5 mm or 3/16\" it appears to be an older style regulator. I checked with ereplacementparts.com but had no luck so far. Browsed ebay. Is there any way I can find this part or use an adaptor to get a newer version? If anyone has any info would be great.
Nancy MacInnis
Any BBQ regulator will work. You may have to get creative for the end that goes into the stove, but like as not, it's 1/8" NPT. Go to the local hardware store BBQ section. This solution would be for using it off a bulk tank.
Rustytank
I'm not familiar with that stove but most of the Coleman propane stoves with flexible hoses have the same attachment fitting. Do you have an outdoor store nearby that you could take the stove into and try the hoses on your stove?
namacinnis
I will try both ideas. Thanks! I've ordered 2 from Amazon as well just to see if will work. Live in the middle of nowhere lol but I do make the odd trip a couple hours away.
Nancy MacInnis
Well, welcome to the community from the middle of nowhere, Oregon!
Best of luck--you'll get it done!
i sold one in the past , found one for someone else like yourself looking for one . i know what they look like but i dont see one on ebay right now .  even if you find one the hose will be old and probobly need new orings in the conector ...... ill keep my eyes out .
Rustytank
Your worst case scenario is buying a stove just like it and putting the rest of it away for spare parts
namacinnis
thanks everyone!Seems a hard stove to find too online.
Nancy MacInnis
you may be looking in the wrong places :-) i dont know propane stuff very well by part numbers , but all the old regulators looked like whats on this heater . it may be a direct swap to your stove but i cant really confirm that BUT the one i sold to guy to use on his stove came from one of these heaters and wile i never heard back he never complained LOL SO I THINK IT WAS GOOD SALE :-)
the same regulator was used on numerous items .
HAVE A LOOK HERE  it has the little red knob . https://www.ebay.com/c/1725245386
this one looks better and its cheaper , https://www.ebay.com/itm/Coleman-Portable-Propane-Catalytic-Heater-Adjustable-2000-5000-BTU-UNTESTED/303564352033?hash=item46add86a21&_trkparms=ispr%3D1&enc=AQAEAAADYO%2FAoK%2FrK3JHtX8OR6fZYQ5ZJzefaSqV6FvosEJebVb8cd0MxuVSFWSN2q%2BxNnGiANgRxH7amgBye7bWx%2B71uNKTrpU3urS5VybF9JUADwMi3jyqdGdrYCEpUAN6Kge2C263GdyXogyCzjtCG9xc7xvczosH1O3BE6U2c1YEI65Nj4Q6uj0aNVu9GC74PQ0LOYZfxp6iM7oZ%2Fvn7yHTkORWyIGiyWbuASfmOvXvCrYuR2mS7lgCdDOiBJmN8rm2rwfsVmQy9e%2F7wzIuHyxckz6Qqw2QlS%2FC021I8vqUjwAOiVqGuYBO6DQ3cEfQyImlT4TE8v0KowGdzvpm7w%2Ffa1EqlnYA6MOGVhvDOQ2vl8aoCBzN5RWG%2BHx80TPjsboLzGCQmRnVHhmSHYfq2BQeS%2BwzAxvDHU5sbojDq7fO357T9rNLLVIu5gv%2FYYZ7NHai%2F5iOeNJtoTnu1vvs3ycDfKFqTp82C7cchXj3eIOgz4EjOSBIixDL%2BgNUGaUgf8J4tP8kbG%2BHOu8SC8HsEPk14achb1eERm5DihltgxD1MVRmHYNItlWlppHKpjQr4GtnRB6mPONxxVQ89rkH71p2%2BidtauWHs1rl%2BcCwpWuFVJl8ylrJWgCKMZOz5Hi2HKouRmlKwwsUExu%2FqSt4%2BLAEzul3nEGh0iAnU1DrXPHgwKTQmqMr%2B3NnGINEc%2FNLwfMeNso1k1gL9oxCtotKufAiAbPGAuN4H%2BLu1DyeGCQ5d3HrEggVqd7frlAQAeFU9dfsKU7fiHJHEcIXaPd3G8vJOovkd8WOqmGPSEWJI4I1w6vUhVN860liikEagSAisT2s%2Bzdb0ipjmsL0%2BGFOimnG0De%2BthfetdxSCfsHN%2Fkmtq%2B%2Bva8pc18awVDNr5CtVsWMKWB7Z7TLnmPMzrAiviu5C%2BZmf33CgBW2k4xAAJ2ubq4DtbAfDBCSz%2FKM5nt%2FfTQUXmiaAk2XKfa6uxHeb0NsaJkfTZ%2BmfbqD7utFkp2UF8YO4lltS21R50raMVylHLP65bqN3ZKhHMYG4bh8opwcuxH2SM9bW3NsYbwXGLNkBUSZqkIICt9A72VC%2BDsCeJeAd5ksDcXAfOGBcemmNiGmU6JVIKY0et3uoC0GNXQ8QWck%2BP%2FXbnfjsIxvi2OdOU78KLg%3D%3D&checksum=303564352033978f8de6e51d4a208402e11636451235
these regulators show up on ebay now n then , usualy about 20 bucks by themselves , just have to keep looking but now you know what your looking for .
Usually there are 5 propanes for every gas stove here locally and some are always dirt cheap.  Not today!  I've never seen so many gas stoves, or so many overpriced propanes!
I was going to find one cheap/local and offer to get it for you...
macwacs
Posting a photo of the stove might help us identifing the part you need. I have one prop stove (1988) in the box and none of the numbers that you give match with what I have, but the fitting Doc Coleman shows on the heater looks exactly like what I have.
 RMW
StanDahl
That's a Canadian model, and I don't know if or what the Coleman U.S. equivalent is. Here is what the hose looks like:
[image]
macwacs
Thanks StanDhal that helps alot. My fitting definatly dont look like that. That looks like it is for the five gallon tanks. My connector is for the small one gal.Tk. but the stoves look very similar
 RMW
The key for the hose is the connector for the stove.  Coleman used a couple of different ones over the years.  I suspect Nancy's is the smaller brass barrel screw on, based on presumed age..
namacinnis
StanDahl, yes my stove looks like that and is Canadian. The hose looks familiar but just going by memory.
Nancy MacInnis
UncleFred
I purchased a hose like that from another forum last September.
I replaced the o ring and it worked perfectly.
The fitting on the stove end is the key.
I have photos somewhere but could not locate them just now.
Everyone's Favorite Uncle
namacinnis
B6961EA8-4DB2-4D2A-857C-3657050232B3.jpeg Here’s the end of stove connection
Nancy MacInnis
hahoe03
I might have an extra one downstairs.
Mike Trigg
hahoe03 - FAS #013 Confusing Future Generations of Collectors, One Lantern at a Time!
namacinnis
That would be great, I’m in Canada FYI, might be pricey if sending out of country but if it would work on this Canadian version might be worth it. Especially if the ones I ordered online come and don’t work.
Nancy MacInnis
hahoe03
Hi Nancy
I do have an extra one. I will PM you
Mike Trigg
macwacs
This is the place to get things done. It might take a little while but good things happen here. All of the people here deserve a thanks one way or another. Greatest community ever!!!!
RMW
Brooke strange
Hi, nancy I seem to be having the same issue you once had I'm looking for the same hose thingy. You mentioned you did order something on Amazon and I'm guessing they were still delivered? did either of those work ? do you mind sending over the link if they did.
namacinnis
Hi, no i had to send both back to amazon. Is yours also a Canadian stove?
Apparently very hard to find parts [frown]
I can send you the link to the ones not to order lol. Let me know if you want
Nancy MacInnis
Brooke strange
Yes, I have a Canadian stove as well, dang I was hoping you had some luck in getting the right match on amazon. I can't find the part on eBay anywhere i definitely thought it was going to be easier than this
hahoe03
These hoses are pretty hard to find. I had a couple of extras, but Nancy took my last one.
Mike Trigg
namacinnis
Still looking for the very rare Canadian regulator. Many thanks to Mike for sending me one, it was a bit too small sadly. I'm going to hang on to it in case I can find some sort of adapter -but in meantime if anyone has a lead that would be great.
Nancy MacInnis
