10gage
So I picked up this cq awhile back cleaned it up and realized the bb inside the cap was misshapen and leak air back out at me. Is there a good way to repair this? I was thinking about pulling back the tabs a bit pulling the old one out and replacing it with something similar and beating the tabs back. Has anyone done this before? I figured I would check first before I don’t ruin something. Thanks in advance. 5E93107B-E36E-45F1-A159-66731A91D051.jpeg
James sizemore
milspec syndicate #1941
slant savers #68
quicklite crew#43
If the check back is misshapen I'm not sure you could hurt it any more... I'd try it ðŸ‘
surffisher60
James,   what could possibly go wrong, +1 on throwing a bb in and pump it up  !
bob
id try some lye and then a citric soak first , lye to remove any organic material , citric to soften the rust on the ball , they poke at it with a shishkabob stick removing the softened rust .... or try another cap .
10gage
Well and pulled the tabs back a bit and got it out but this is a pretty small bb. If you look close you can see the flat spot and a little raised area off the flat which is what is causing this. F2AA4DD3-0BAD-43E8-8BED-123A9EA130DD.jpeg E4D95E66-5705-466F-8FF1-0A23E2FCAF8A.jpeg
James sizemore
slant savers #68
quicklite crew#43
10gage
A3FE6E16-7406-41F5-BED1-9D024F8B0796.jpegI wonder where I could find a similar sized b b. i guess i could pull apart a old shotgun shell and see if i can find something similiar and steel
James sizemore
slant savers #68
quicklite crew#43
if you search the forum the size has been documented but i dont remember of hand  , its the same size in the 427 check valve ( penis pump ) as i recall they were found at a bicycle shop , same size if found in all the coleman regular check valves  but if the size is found im sure you can buy a thousand of em online LOL
Rest in Peace Christopher OR is the one who determined the size and sent me a couple years ago for other projects  0.125 is the size
try this thread https://www.colemancollectorsforum.com/post/427-external-pump-check-valve-does-not-seat-6360191?highlight=025&trail=50
10gage
Well I checked another cap to see if the bb inside would take a magnet and it didn’t. The bb In the one I’m working on does not take a magnet either. So I’m assuming these are lead bbs to begin with. So I pulled a piece of shot out of a old Wax paper shotgun shell That had a similar size and Installed it. But it only slowed the leak a bit. Any ideas?
James sizemore
slant savers #68
quicklite crew#43
10gage
thanks Steve
James sizemore
slant savers #68
quicklite crew#43
The seat may have debris in it or a bad spot... Or the new BB
10gage
Yeah I might get some of these ball bearings Steve above mentioned in a old post and try but it seems my eyes don’t want to work well for me today and it’s so damn hot out
James sizemore
slant savers #68
quicklite crew#43
Get a stainless ball bearing and you're good for life. McMaster Carr has every size you could imagine, but you might need to buy a hundred.
I'd pull that lead shot out and try to clean the seat in the cap. I've had good luck with a toothpick wrapped in 4-0 steel wool for cleaning seats.
10gage
I’ll try that thanks
James sizemore
slant savers #68
quicklite crew#43
BTW: 0.125" is 1/8"--a very common size. You should be able to find a hard-chrome bearing at the hardware store.
They are not supposed to provide a perfect seal, that is why you screw it down when done pumping. How bad does it leak?
10gage
Enough that it would shoot a lot of vapor out if I wanted to pump up while running. My other ones shoot out when I loosen but seal almost immediately. I’m going to order some tight tolerance 1/8 stainless bearings and try polishing the seat well and I’ll take it from there.
James sizemore
slant savers #68
quicklite crew#43
You could regrind the seat lite a mini-valve grinding.  Just need a ball glued on the end of some sort of stem and a bit of compound.  Might be easier to just round the end of the correct diameter rod and use that to finish the seat.
I have had a couple, notably Leacock, caps with new balls (and in their case, seals) that didn't seem to seal well until I had some pressure on them.
I was thinking yesterday that if everything else fails you could always drill and tap it for a valve stem.
bwperreault
The ball can be driven out with a small pin punch without prying the tabs back. The tabs will get out of the way. Dress the seat with a drill bit (smaller than the ball) by hand IF it needs it. Put in a new steel ball and tap back in with the punch. Tap the ball lightly to seat the ball. It'll work. Ya might have to tap the tabs lightly as well to keep the ball retained. As someone mentioned, it doesn't have to seal completely, just slow the air leaking out. The screw's taper and seat seals it.
10gage
Well the 1/8th stainless bearings showed up. I popped one in lightly tapped the tabs with a punch and it works perfectly now
James sizemore
slant savers #68
quicklite crew#43
so how many did you have to buy ? you have extras :-)
10gage
50 on Amazon For like 6 bucks free shipping. Better than having to buy another one or use a replacement. And yes I do have extra you need some? I’ll send ya some
James sizemore
slant savers #68
quicklite crew#43
Many of my old plugs don't seal, I have to hold the pump shaft down while I screw the top part down.  Vinegar and lye were no good.
