o2badad
Hello all,
I have a crack in my brass fuel line. Is this repairable, or do I need to replace it?
If I need to replace it, where would I find one? I would love to replace with original parts. Does anyone have a spare they can sell me?
I have tried to find compression fittings to fit the thread (I believe 1/8 IPS, or 5/16-27 IPS), but I am not able to find the size for the thread to make a replacement.
Thank you for any assistance with this.
Bryan
Should be able to solder it, after all, water line for swamp coolers can be soldered which work under more pressure than a stove.
I would silver solder it, the generator gets plenty hot. But yes, just solder it.
o2badad
Thank you Keith and Duane. I will try that. Would you cut in a groove to widen the crack or solder over the top of the crack?
I am no expert on these things, but I would just solder over it. Clean, really clean. flux.
Northman49
Silver hi-temp solder is the way to go.
                 ICCC no.1880
                 CANADIAN BLUES Member #023
                  Mil-spec ops #1982
o2badad
I'll give that a shot with the hi-temp silver solder and let everyone know the outcome. Thanks.
Bumpstop
You can fix it!!!!!
o2badad
I ordered hi temp silver solder. It arrived yesterday. Soldered it up last night. No leaks!
Thank you everyone for your guidance on this.
Nice job.
o2badad
hikerduane wrote:
Nice job.
salukispeed
Nice fix. And very good you went the silver solder extra. As the fuel line is before the shutoff valve and would not be able to turn it off if it were to leak since the tank is pressurized and no shut off
ICCC 1868
Perfection appreciation #10
Milspec 65252
Good on ya!  Is always rewarding when it works.
