JosephDurham
So, I sat down this evening to fire up my new lanterns and I’m a bit puzzled by the Jan-2000 288. The globe has a lot of play in it, around the edge, as well as at the top.
Any input?
Joseph Durham
ICCC #1954
Looking for bday lantern 10/84
Kansas John
You have the wrong heat shield for the that globe base.  Some globe bases have springs attached.  At some point Coleman switched to a heat shield with spring extensions.
I’m putting my daughter to bed and will try to get pictures for you after bedtime.
John M. Lawrence, KS
ICCC #1431
JosephDurham
Ahhhh, wonderful.
thank you!
Joseph Durham
ICCC #1954
25 502s
I think this is what John is talking about. If the base has riveted on springs then it uses a simple heat shield. If not you need a heat shield with the springs on it. These are single mantle lanterns but the concept is the same.  802B67DA-C2F6-40E6-9787-106884D9B02C.jpeg  4DAA2FC2-5D86-4C9E-96E7-D680A5E19C72.jpeg
Kansas John
Yep, Jason has it sorted!
here’s the part you are looking for:
https://www.oldcolemanparts.com/product.php?productid=231&cat=&page=1
You could try placing an ad in the classifieds but I doubt you’ll be able to do much better than OCP’s $5 plus shipping.
ICCC #1431
JosephDurham
So if I get the shield, my globe will fit better, correct?
Joseph Durham
ICCC #1954
It will still be a bit loose, Jason, but there won't be as much movement as you have now.
Kansas John
correct, you can bend the prongs up if you need to.  The vent applies downward pressure on the globe and the springs “cushion” it.
ICCC #1431
JosephDurham
Thank you everyone. Guess it’s just part of learning. The seller told me it had never been fired, and apparently I didn’t know what I was looking at. Seems odd for having never been fired, it doesn’t have the right piece.  Makes me scratch my head. Lol
Joseph Durham
ICCC #1954
25 502s
It does look unfired from here and most people agree the 288 is a great lantern.
Kansas John
Did you polish the generator and burner tubes?  I have never seen an unfired lantern with that level of shine on the exposed brass bits.
It may never have been fired.  Factory mess ups happen.  My first NorthStar dual fuel had the wrong generator on it from the factory.  There was a recall on that model for a few months in 2011.
ICCC #1431
JosephDurham
I wiped the majority of it down with simichrome, but it looks just like it did for the most part out of the box.
ok, well that’s good to know. Like I said, a lot to learn for this newbie.
I appreciate everyone’s help though. Hopefully one day I will be able to help others as they start their collection.
Joseph Durham
ICCC #1954
Until you can get the appropriate parts, you might be able to shim the globe a little to reduce the rattle. To get the below globe to not rattle in my 285 lantern, I used some simple shims made from folded up aluminum foil. The frosted globe is ~1/8" shorter than the normal globe and rattled even sitting on the globe springs. Get strips of foil about 1" wide and start folding them over not so tight that the piece can't be folded. I put mine on the top so they are not noticed. Don't make the foil pieces such that tightening the vent nut puts much downward force on the globe.
austin65uri
I don’t have this model and can’t comment on the heat shield issue, but a lot of globes rattle a lot and were designed to do so. If the lantern appears new and works fine, what the heck. ðŸ™‚
Bill.
ICCC#1601
arizonacamper
If you are concerned about the rattle when you are transporting them you can try doing what I do. I have some clean shop towels that I fold over and wrap around the globe on the bottom. I put it between the frame and the globe itself like on my 200s it keeps the glass steady so it doesn't rattle and possibly crack or break while you are transporting them. It works great in my truck which rides really rough.
Lanterns are like tools.
Kansas John
austin65uri wrote:
I don’t have this model and can’t comment on the heat shield issue, but a lot of globes rattle a lot and were designed to do so. If the lantern appears new and works fine, what the heck. Ã°Å¸â„¢â€š
these lanterns don’t have cages or uptight supports like the CL2/220 series/or 200a.  They need the springs to keep the globe in place if moving the lantern from the patio to garage, let alone packing and driving anywhere.  Without the spring, it’s feasible the globe could shift/tip and wack the mantle or break on the circular mixing chamber.  Don’t ask me how I know....
ICCC #1431
No globes seem to rattle as bad to me as a newly acquired 242 globe in the back seat of my truck. Especially if it’s a desirable globe.
austin65uri
Thank you John.  I understand the issue better now.  Might even have to buy one of the darn things!
Bill.
ICCC#1601
Flyboyfwa
Glad you got your question answered. I just recently got my first 288 and was looking for the same information. Previous threads and info from this thread helped clarify it for me. Now let's see a money shot.
Greg is right. The more desirable the globe the more they rattle and the higher your blood pressure goes.
Andy
Mil-Spec Ops #199
Coleman Slant Saver #54
Coleman Quick Lite Crew #06
The Coleman Blues 243's #159
ICCC #1741
JosephDurham
I appreciate everyone’s help. I have a lot to learn about Coleman lanterns. I look forward to the knowledge I’ll gain here.
Joseph Durham
ICCC #1954
