brice49
Just want to confirm before ordering, that the 234 uses the same generator as a 201 lantern?  Also, is there anything special to use to fill the pre-heat cup, or just take the top off and use a small funnel to reach down to it. Do you fill the cup with kerosene too, or some other type of fuel such as denatured alcohol?
https://www.oldcolemanparts.com/product.php?productid=69&cat=&page=1
Just tying to figure out what all I need to order up front.
kero will make a sooty mess using it preheat , use denatured alcohol it burns clean  . or a propane torch :-)
Otto
Same gen as 201, Coleman had a little can with a s shaped tube for filling the cup with alcohol, through the larger hole in the base plate. Now, there is a plastic bottle for that purpose. Amish shops sell them, or on line.
Otto-Western Wisconsin Gas Pressure Appliance Safaris
                      ~ stoves are important too~
MilSpecsOps  #1979
Coleman Slant Saver   #28
Quicklite Crew.   #16
Gavercronos
Like the Dr. says, use alcohol. Put it in the cup with one of these so you don't have to take off the vent and globe:
http://www.oldcolemanparts.com/product.php?productid=68&cat=&page=1
And yes, that generator will work on a 234.
WillCat
Chautauqua County, New York
Slant Saver [svg]
the original gennie had a captured pricker. There was a little crimp at the base.
58idaho
I skip the pre heat cup and use a small blow torch to pre-heat the generator.  It seems to work better for me.
brice49
Thanks everyone for the responses. One more thing I forgot to ask. What is the correct check valve for the 234?
The original part number for a 234 is 216-538.  I think it is the same as early 220's.  Mike at OCP has them for sale.
https://www.oldcolemanparts.com/product.php?productid=3845&cat=&page=1
This begs the question - does anyone have a chart that lists check-valves by Model #?
Dmacp wrote:
the original genie had a captured pricker. There was a little crimp at the base.
I purchased a 200A a month or so ago and had the same generator  as per your description and had to get a pliers to pull out the pricker it from the gen. First one I came on with that feature
it uses the same CV as all the later 242/200/220 series .
This is the little alcohol bottle that some have described for filling the pre heat cup.  Click image for larger version - Name: 9376E7AB-2272-4777-9F13-6B80500C1F54.jpeg, Views: 49, Size: 98.44 KB
you can go off on a tangent just collecting all the different spirit cans, or "Automatic Cans" as the Swedish called them.
Originally it was methyl alcohol (Methylated spirits)  they used ("Meths" as the British say).
