72merc
Hello.  How critical is it that a check valve seal the fount completely when the stem is unscrewed?  There have been a few lanterns I have worked on where the check valve never really stops air from escaping the fount unless the stem is screwed all the way in.  I am checking this by pumping up the fount, closing the stem, starting the lantern, unscrewing the stem and then holding my thumb over the hole to see if it rises.  I have a removal tool and have removed them, soaked them in vinegar, cleaned with carb cleaner, swapping from one lantern to another, etc. and nothing I have done ever seems to get them to seal completely on their own without the stem being screwed closed.  I have read on here that a pump rising less than an inch per second is acceptable, but the rate the pump rises seems to be dependent on the amount of pressure I apply with my thumb.  Is there something I am missing?  Or do I need to be concerned about pumping one of these lanterns when it is already lit?  Thanks in advance for any help or advice.
72merc
Check valve seldom makes a perfect seal, and is not designed to. That's why you have the air stem.  Tighten air stem after pumping, enjoy light!
Pumping lantern while it is running is fine.  But after a good bunch of pumps 30-40 it should run for a good hour or two? before you have to. If it does not run long without pumping, have you changed the cap gasket?
Smudge
I've seen in a video, where someone suggested that you need to hold your thumb over the pump opening, while tightening the stem valve. That's simply not true. As Keith mentioned, the amount of air escaping from the check valve, while pumping, is negligible.
A bad CV is one that prevents you from getting any pressure into the fount.
Most leak some, but not enough to bother me. My L427s have CVs that, even after cleaning, barely hold pressure enough to allow me to pump 'em up. Combined with a pump know with no air hole, it can be a PITA.
curlyjoe_99
I have a couple of CV's that I have to do that thumb hold on. they work fine otherwise.
the  recourse, if you are not willing to accept or the air escapes to fast to keep the fount pressurized, I have found is to :
I use a fuel cap that has a schrader valve and put 30 PSI into the fount. then quickly open the pump 3-5 turns and you will hear air escaping and the ball eventually makes a ttssssbbbttt! sound as it seals. if this works, at least the seal and ball are good. sometimes this will solve the issue with a drop of machine oil on the ball as well.
Other times I have had to pull the CV and either replace with newer or scrub/polish the CV-Ball then press down a bit on the three tabs that hold the ball in place. My theory is that this brings the CV-Ball closer to the seal point and it takes less air pressure to make it seal.
hope this makes sense and helps
Tigerfans2
I'm not going to respond to this thread.
Coleman Slant Saver #58
Coleman Quick Lite Crew #8
Coleman Blues 243's #16
Cottage_hill_bill
Seems you already did. [smile]
Reese
North West Florida
Tigerfans2
but I was nice
72merc
Thank you to all for the help, I appreciate it.
72merc
