grob
Here is a cast iron burner on CF. (413B)
[413b_2s-97318234]
Here is a cast iron burner on drugs (propane). (3H)
[cole_3h_props-19160198]
Get the picture? Gar
PS: Really roars and gotta make sure it doesn't melt anything!
- Foggy
gwillmot
What was the pressure of each fuel you were passing through the burner?
Moon Shadow Eliminator
smallenginelover
Propane vapor pressure is 60psi, there could be a regulator on it but likely not. 😉
BernzOmatic Appreciation Club #072
Propane pressure is highly dependant on temperature.
At -44F, it's essentially 0 psi. At 100F, it's about 175 psi. http://virtualmark.net/wx/pressure.htm
My unregulated propane adapter does pretty much the same thing on my 426. Fairly impressive!
grob
- The 413B photo is not mine, so don't know. My 3H runs a larger flame than that on CF, but nothing like on propane. I'll run about 60 pumps on CF.
- The 3H photo is mine and using a propane adapter. I've used it to heat large pots of water to get a hot tub going for a party and melt lead for bullets. No regulator. I have 2 of them and one runs much better than the other. The lesser one still runs good, but it did spend a few decades outside. Used it on a 426A 25 years ago. Have to try that again.
- Foggy
