I have a few Canadians lanterns they for some reason I was looking at the vents nuts and found some really interesting differences. I wish someone could reproduce the one in the middle, when I got my 249 lantern was like that, vent stud was steel very rusted and vent nut was stuck in there looks like previous owner tried some pliers on it. All I did was quench, quench until came off; had to buy a new steel vent stud for my 249 and wearing the same vent nut, wish I could find a sale one.
First vent nut pictured is from a 242k and look at it is a bit shorter, knurled rim is wider that the other two. Last one in the picture is from a 242b and is the most popular one, they are either nickel or bare brass
“Solo sé que no sé nada”
westy
Same vent nut. I don't know when this has been used.
It's very interesting.
https://www.colemancollectorsforum.com/post/242b-seafoam-ball-nut-questions-10436933?pid=1310830185
Cold Start
Hello Junichi. Checked my Canadian 242's and 247's and my early 1935 to 1937 models had the larger diameter shorter length ball nuts. My painted font 242B from 1942, 1943 both had the grooved bottom flange. All others had the regular ball nuts.  Cheers, Andrew
North of -40 C
i have a few like the one in the middle , i thought they were early so put em on my 242K's . this questions comes up now n then , no definite answer i have seen yet .
Cold Start
To add clarification to my earlier post, that it's likely a coincidence that they were on the my mid 40's 242B, as my other similar dates had the common flange on the right as Pancho shows in his opening post.
North of -40 C
major_man
Believe someone posted this previously and think there’s another version
Another thing I’ve found on a few 242k is they had the US style nuts
William
WTB or trade for poultry or USFS.
If they weren’t turning them on screw machines you can’t count on total uniformity. Even with a screw machine they could vary from setup to setup. I had friends cranking out similar pieces for other industries in the 80’s. It was piece work and most operators weren’t trained machinists.
I frighten easily!
mine came from different lanterns and different years
Left is from a 242k 9/35, middle is from a 249 SCOUT B/42 and right is from a 249 SCOUT 3/48
I think I've replied to you in another post but if you have any spares PM me
westy
Hello Andrew. I'm still interested because I saw this ball nut for the first time. Also, I saw the nut on the left side of the photo of Pancholoco 1911 for the first time. Pancholoco 1911 Thank you for posting the photo.
clifforddward
I could turn these vent nuts in brass on my South Bend Lathe...pretty sure I have both a straight line and cross knurling wheels that would match the pattern on these 242 nuts...what is the interest in these and what would they be worth?
Cliff Ward
Cary, North Carolina
ICCC #1955
