loco7lamp
Hi All
Had a visit with the lamp legend Neil Macrae recently & he kindly gave me a few "projects" to have a play with , the first being this unmarked base BQ possibly pre 1924 model which had been butchered by some fool for electrcikery with a great gash of a hole made by drilling & the original base nut drilled through too!
I cleaned up the larger of the three holes with a Dremmel type tool & a mini cutting disc to an oblong shape & chamfered the edges , the hole below this one which was countersunk slightly.
The small hole was tackled first by turning a brass top hat shaped plug on the lathe the same size as the offending hole & brazing a length of mig wire to smaller end of it , then passing the wire through the big hole & up into the small one from the inside allowing me to pull the well fluxed plug into place & soft solder it carefully without doing any damage elsewhere.
The drilled base nut was tapped M8 & a threaded brass plug was screwed in to seal it before soft soldering.
The large hole was cleaned inside & out as best i could with steel wool & the Dremmel then an oversiszed well fluxed brass plate with a stainless rod brazed vertically to its centre was slipped into the hole , the rod allowing me to hold the plate in the correct place to flood it with soft solder to seal the edges properly.
The filler cap was chewed up really badly & i machined a new hex surround which was soldered into place too & easier to seal up with a spanner! The large pump was found at a boot/garage sale & made to supliment my Coleman ones using this is so much easier just four pumps & your there , the adapter uses a Primus NRV threaded fitting which screws into most Coleman filler caps like this!
Well thats enough guff here are the pics , enjoy!
Click image for larger version - Name: DSCF8577-min.jpg, Views: 127, Size: 127.96 KB Click image for larger version - Name: DSCF8575-min.jpg, Views: 125, Size: 138.08 KB
Click image for larger version - Name: DSCF8580-min.jpg, Views: 125, Size: 91.46 KB Click image for larger version - Name: DSCF8581-min.jpg, Views: 128, Size: 63.34 KB Click image for larger version - Name: DSCF8584-min.jpg, Views: 127, Size: 172.94 KB Click image for larger version - Name: DSCF8585-min.jpg, Views: 125, Size: 84.33 KB Click image for larger version - Name: DSCF8587-min.jpg, Views: 126, Size: 143.95 KB
S'pose he's out in the shop fettling another lamp or stove again!!!
Looking for a 12/64 birthday lamp[Yeah]
Dean Dorholt
That is some nice work there!
ICCC #1686
Looking for a 2-60  Birthday Lantern
The Coleman Blue's 243's #131
Coleman Slant Saver #10
mikewells
Very nice work!!
Mike Wells
E Bay user name whitegas5152
ICCC # 1038
xvz12
Very nice!  Good job on bringing it back from a terrible fate!  I'd like to run across one of those some day.
Wynn - xvz12
ICCC#1560
MilSpecOps Syndicate #77
Coleman 275 Appreciation Syndicate #0150
Looking for almost anything kero...[wink]
dugan1
That is some very nice work. It looks like it was an exercise in determination! I'm glad it came to someone with the skill set to bring her back!
Albertville, Al.
Flat_twin
Well done!  That BQ definitely deserved a rebirth
Nice job on bringing it back!
peterthevet
Beautiful job - or should I say the master fettler strikes again!! A nice way to rescue an uncommon lamp.
philbotha
Well fettled, Stu! She lives again. You give us hope that other vandalized founts can also be resurrected!
-Phil
Favourites: 238A B/41, 238B 6/50, Petromax 816 lamp, Petromax 827 lantern, Primus 1020, 1060, 1001, 995 lamp, Radius 108, Optimus 1200, 246B 5/41 241A 5/52, Veritas Gloria lamp 1922, Gloria Oxo-Gas 1913 The Evening Star 1924 lamp, The Evening Star 1922 lantern, Sunflame 104(US), Sunflame 106(UK), Bialaddin 300X,TL10, BR49, PL53,
Stoves: Coleman 425B, Primus 96, 523, 535, Optimus 111, Radius 43, Speedmaster 500 D/38
275 Appreciation Syndicate Member #0181 The only one in Africa?
Coleman Blue's 243's. registration #133 (the fourth known 243K)
tonywebber45
Good save Stu,glad to see you are still hard at it!
No honey its not another lamp,just parts for one I already have. ICCC #1479
loco7lamp
Thanks for the comments guys it was nearly a lost cause in Neil's scrap pile & I needed to make a start posting again , but "Never give up , never surrender" , that Tim Allen has a lot to answer for!!!
Tony , yes had a few years in the background but am slowly finding my feet again after family bereavement & hope to get back in the swing properly later this year.
Stu.
