10gage
I’ve looked up old discussions on this subject and decided on buna over viton mostly do to price. My question is, is there a certain type I should get ? I found some 60a durometer stuff. Descriptions aren’t always great on most sites. So will any buna n work?
im tired of failing pips that don’t last long in my m1950. I’m ordering a punch set as well.
James sizemore
milspec syndicate #1941
slant savers #68
quicklite crew#43
gpaguy
I would check out this thread. Lots of good info. here. I just tried a new pip made of Buna in a Lindaman and Hooverson lantern and it didn't work. I ended up buying the same Viton material that Bob did and that stuff was 54 dollars for a 6 x 6 x 1/8" piece. ouch ! And we don't know about it's long term durability. Then make your decision.
https://www.colemancollectorsforum.com/post/new-pip-material-10597458?pid=1312374897
James, I've had good luck cutting automotive o-rings. Find the right diameter then get a sharp thin knife or razor blade and cut them as flat as possible. I have a huge selection of o rings here at the shop so I don't really know what I grabbed now... I believe they are 4.5mm? Still working last I checked in my M1950. One word of caution, I have never tried it in cold weather. I would think that might make a difference.
10gage
i did that recently on my m1942. I need to pull that one out and see.
James sizemore
slant savers #68
quicklite crew#43
I think I used the same o ring to do a couple stoves a couple lanterns and a blow torch or two... None of them are everyday users, but I check them now and then and seem to always work... I'm not a pip fan..
10gage
me either I would love for someone to develop a check valve to be screwed in the the bottom of these.
James sizemore
slant savers #68
quicklite crew#43
In my experience either BunaN or Viton at 60-65 Durometer are good.
Buna N (Nitrile rubber)  at 60-65 duro is perfectly acceptable for a pip. The question being: Is it really Buna N?
A lot of us chimed in with opinions and experiences on the link provided by gpaguy. It's fun to play around with materials, but really it's not that bad to change on an M-1950 or M-1942, so if you just plan on changing it once per year at the beginning of the season I don't think it's too bad. I think my one sons has been running an ECH or BunaN 60A in his M-1942 MOD for three years without issue and he uses it a lot. I'm currently running Fluorosilicone in mine and it's been perfect. Like Viton, Fluorosilicone is expensive. I have sheets of all that stuff.
A conversion would be tough (I've thought about it myself) because the ball check valve is meant to have a stem to close it tightly after pumping, so to do that mod, you'd need to modify the pump assembly, too. If it's the transport you don't like (risking fuel seeping out) then removing the pump during transport and replacing it with a solid cap would be a good solution, like this (except where do you store the pump?):
I've been using one on my M-1950 spare fuel can like the one on the left in the photo (along with a plug I made for the middle):
10gage
 and that’s it The ones I’ve gotten don’t last 2weeks. So I dought it’s good buna n
James sizemore
slant savers #68
quicklite crew#43
If you got them from our usual source, there was a problem a year or two back with pips swelling to where they would pass no air. I hope that's been resolved. Obviously, their source was passing some bad goods.
10gage
thats where they came from
James sizemore
slant savers #68
quicklite crew#43
