Looking at this I’m assuming I need to remove the pip “cover” and pip to replace zee pump cup?
I did some searching here but struck out!
click on the photo for high Rez photos!
thank y’all! Trying to not bugger it!
https://photos.app.goo.gl/YmMc4YZaA7VARXN58
I frighten easily!
a big screwdriver to undo the brass round nut at the bottom .
I frighten easily!
Erwin
Kevin,
the brown bomers seem to be real dirty.
My pump was ok somehow bur the pick-up tube was a mess. 😧
IMAGES HERE
Good luck, Erwin
@Erwin
this one I’ve lit before, not sure how I was previously able to pump it up as the pump cup was split in many pieces. It actually burned pretty good. I will throw a Tilley cup in it tonight and let it rip!
Thank you
I frighten easily!
Macburner
A Tilley pump leather may be a bit small. I don't know what size PW pump tubes are but most lamps such as Bialaddin Petromax Etc are about 17 to 17.5mm. Tilley are 16mm and Coleman normally 20mm dia. and in general both are not suitable for any other brand. ::Neil::
Neil
Thank you, I had read somewhere that the Tilley will work. I will report back.
I frighten easily!
I'm pretty sure they have a small bore pump tube? If so? the 327 Quicklite pump cups will work..campinut..
@Macburner @campinut
The Tilley cup works very well!
I frighten easily!
