Thinking about making some of my own straight walled globes if it's cost effective. Wondering if anybody else had tried this or had any luck finding the right sized tubes. If I can successfully find them I might try my hand at sandblasting some designs again. Been several years since I've done it. Anybody know of a source with larger Pyrex tubes? Thanks
Fred Kuntz might know.
It's probably a lot more cost effective to buy them from Fred.
I hate to ask Fred as that would be like digging in his pocket so to speak. I have nothing against ordering from him, but like doing things myself... Even if it cost a little extra sometimes ðŸ˜
Google it. I looked a while back and found several sources. Measurements will likely be metric, so be prepared.
Minimum order size shot me down, IIRC.
Cutting larger tubing like this is not like cutting lab tubing. If you have experience cutting bottles, it would help. You'll probably also want to flame-polish the edges and you'll need a bigger torch.
Timm, I've hunted Google a bit and can only find laboratory sizes. Since I made this post I did find some on Amazon.. But delivery would not be till September/October...I may be on to a different hobby by then...
I wasn't suggesting that you buy Pyrex tubing from him, but that buying finished globes from him may very well be more cost effective than buying the Pyrex tubing and making your own.
Now you're talking like a successful business man... I on the other hand work a little harder... to spend a little more money... To say I did it Ã°Å¸ËœÂ
Jim I was actually referring to Dan's post to ask Fred.
freds come with the proper logo and are very affordable , but do as you wish
Looking again, I was looking at borosilicate glass cylinders. Look in glassblowing supplies, not lab. Unfortunately, I measured a 220 globe and it's 4 7/8" dia. Not an easy size to find! Checking the fit of a 220 globe, there's little or no slack there. 242 glass at 3.5" (89mm) ain't going to be easy, either.
Toby,
Spending more to do something yourself is totally understandable.  It's nice developing new skills even if we don't need them.
That's what I'm finding.
The logo part is easy, if I just had the glass ðŸ˜
bowenstudios
I looked into this before also, as I like to play more than buy. I found the same problem Timm did, the minimum order was crazy. I was hoping to find it in colors like the tubing used in neon signs.
-Mike
Mil-SpecOps #0651
The Coleman Blue's 243's #154
I may have found something that won't break the bank. Anyone know the thickness of the 200/242 size globes off the top of there head? I'm away from the shop for the afternoon or I'd check
H_E
I may be missing something but would the thickness be that big a deal(within reason)?  Seems the diameter would be more important.
Hercel
Not just another pretty face.
Hercel, clearance is fairly close on the 200/242 burners. A little leeway but not a lot
H_E
Tape measure looks to be about 1/8"
Hercel
Found some 3 1/2" x 8" that could be cut in half (if I can successfully do it that it's) but if I'm reading the description correctly it is 0.090 That might be close enough to try.
bowenstudios
I just checked a couple and the flame polished bead is reading .08 to .1, hopefully that helps
-Mike
Mil-SpecOps #0651
Thanks guys
H_E
The originals are just a smidge past 31/2 outside diameter (top and bottom) and 41/8 tall.  If you are successful, and here's hoping, post up some pics.
Hercel
Searching the Alibaba site might produce some sources. The below might be worth looking into for larger quantities. One might be able to hot wire cut the tubing.
https://www.alibaba.com/product-detail/Borosilicate-Glass-Lantern-Tube_60733940689.html?spm=a2700.galleryofferlist.0.0.5a3257cbmOUjO5
Thanks zoomkat. If I'm reading it correctly, looks like a 100 kilogram minimum... That's a lot of globes ðŸ˜
The below company appears to do colors and shapes in glass working. You apparently can buy samples, but they may need something to copy or good photos and dimensions of what is wanted. No harm and cost to contact the company tech support and see what they can do. Red, blue, green and amber globes might be possible, in both straight and tapered.
https://www.alibaba.com/product-detail/High-Quality-Durable-Using-custom-round_60778402061.html?spm=a2700.galleryofferlist.0.0.61c21c773aOFFG&s=p
