Blue painted Sears lanterns seem to rarely have much paint left.. At least in my case. So I've repainted 3 of them and noticed the older ones look to be a little lighter blue... Anyone have a better paint match than Chrysler blue? Pics for reference:
Two on the left are original paint, two on the right are repaints.
This later one actually matches the vent pretty well. All three were painted out of the same can of paint...
Flyboyfwa
I got a can of that and tried it. It came out almost a navy blue. Not even close to the color on the cap or in the pictures of people that used that to repaint a lantern. I also tried to use the often referenced list of paint colors. After looking on line and going to almost every paint store in town I was unable to find the majority of the colors listed. I was told they are old and no longer made. It might be a good idea to update the paint list.
Has anyone had better luck lately? If would be happy to be wrong here. It would be nice to find a better color like the poster above.
Andy
Mil-Spec Ops #199
Coleman Slant Saver #54
Coleman Quick Lite Crew #06
The Coleman Blues 243's #159
ICCC #1741
OregonMichael
The closest I've ever gotten has been Plastikote #232 Chrysler Blue engine enamel.  Even that was just a tiny bit off, but close enough where it's not noticeable.  I did this set about three years ago, or so...
I've not looked in a while, but the last time I tried to find it, it was getting pretty scarce.  The local Baxter Auto Parts was the only local place that had it and they had three cans left.  Might be different now.
Frank6160
I think the plastikote color has been discontinued. You may want to spend the money and go to an auto paint supply store and have it matched. I think it runs 15 to 20 a can.
Frank
If It's Coleman
ICCC #793
The Coleman Blues 243's #44
Try using a white primer to lighten the topcoat. Works better with some paints than others.
Sourgasjohn had some mixed up at a paint store with good results. Touch base with him
Thanks for all the suggestions guys, not sure I would repaint any of these three, maybe the single mantle... But seems that most of these are missing their paint or rusted badly... At least in my neck of the woods. But as you can tell I've had a few show up recently so there may be more to come?.. still need a red/black big hat... To go with the big hat collection.
I ran into the same thing when I did my blue Sears. I could not find the Plastikote. I used the DupIi Color like you did and agree, it is darker.  I am going to try Light Blue Ford Engine Enamel from Dupli Color. It looks real close by the color of the cap.
I'm not familiar with the light blue Ford color. The Ford engine blue im familiar with is pretty dark
My local NAPA store had both, Light Blue and regular Ford Blue. Both from Dupli Color. I need to take a fuel cap in with me to check and see how close it really is.
Flyboyfwa
Here is a cap I tested it on. Same one as the OP. Not even close.
Andy
Mil-Spec Ops #199
ICCC #1741
Thanks Dan, I'll check into it if I plan to paint another one.
clifforddward
Without even addressing the availability issues, the earlier posted did hit on an importing point...that being the undercoat (primer).  The tint of undercoat (black / gray / white) will have a tremendous effect on the final color.  Blue colors often respond well to white undercoat to "brighten" the final shade.  Reds are quite affected (positively and negatively) based on undercoat...I often stick to gray for reds as I once ended up with pink when I sprayed red over white.
There is much more involved with this topic, as it depends on the pigments and basecoat, but in general best to test.
Cliff Ward
Cary, North Carolina
ICCC #1955
I've always used a self etching primer on my lanterns which is a green color. I could probably spray I lighter coat after that to brighten it up some... I find it odd that all three of these lanterns were painted out of the same can, and each one got darker as I went... Maybe I didn't shake it up long enough... Think if I go shake the empty can it'll brighten them up?... ðŸ˜‚
dodge trucker
Ive sprayed allot of Chrysler Blue out of rattle cans and that cap looks like no "Chrysler Blue" I have ever used.
Looks like Ford blue in the pictures
