jleone
How do I put on a bernzomatic decal?
John B Leone II
25 502s
Right side up and level!!  Just kidding. Peel the backing off as you go and get rid of air bubbles as you go.
jleone
Jason I feel pretty stupid.  I thought this was a decal that needed soaked in water. Yep you are correct. just a sticker.  Don't be throwing m250's and drinking at the same time.  Enjoy the rest of 4th. God bless America!!!!!
John B Leone II
Take a little liquid soap and add to a bowl of water. Peel off  backing and set face up to coat glue side of decal. This gives you some time to position decal perfectly and scrape out air bubbles before it sets up..campinut..
mnhogrider
This is how I do all my decals. A little warm soapy water then wet the surface and wet the back of the decal after removing the paper. You can slide it where you want it then press out the water using a paper towel.
ICCC Member #1396
Mack, Cat and Cadillac.
