mgmlvks
Realized a while back that "Amish Fuel Cap" can mean different things!
Thought I would share my five basic variations
[50067425257_7a095206eb_z]
[50067427907_e552aca5df_z]
And then these variations on the end of the CV (maybe two rather than 3?)
[50067428332_0ed47e68a8_z]
Francis Bacon
Gavercronos
So what I'm seeing is: a Leacock type; two kinds of Schrader valve caps (one purpose-made and one converted from a regular one-piece?); a handpump type with a NRV; and a handpump type with check ball (AKA regular Coleman lamp cap). Correct?
WillCat
Chautauqua County, New York
Sandman
I always liked that leacock cap on the left......never seem to have any problems with them
ICCC  #1869
Coleman Quick-lite crew #25
Coleman Blues 243 #158
mgmlvks
Believe all but the middle cap are "manufactured" by someone.
Leacock Coleman Center shows at least three of these and some others at
https://www.leacockcolemancenter.com/standard/search?q=filler%20cap
I have made a number of caps with short Schraeder valve tapped into new one-piece caps.
My thoughts below - feel free to educate me!  I really like the as-issued Leacock caps, but have become a fan of the safety cap due to the positive shut off of the thumb screw.
L-R (and Wiilcat was correct)
  • As Issued current Leacock Lamps
  • Schraeder Valve (from Pitman Marine - eekpay)
  • Schraeder Valve - appears one-off (likely homemade)
  • "Safety Cap" (Pip with Spring) - manufactured
  • "Safety Cap" (Check valve with Ball) - manufactured
Francis Bacon
mgmlvks
They are pretty handy if you have an air compressor with a rubber tip, especially if testing or troubleshooting lanterns.
Francis Bacon
If one is going to get involved with lanterns as somewhat of a hobby, a Schrader valve fuel cap is a smart investment.
gwillmot
Still not convinced about using an air compressor to fill up a lantern.
air boom.jpg  Makes stress cracks look good!
Moon Shadow Eliminator
That is a concern that is mitigated by using a pressure regulator. Set the regulator to 30 psi and you should be ok. When I’m leak testing a new acquisition I make it a point to pressure in steps. Regulator set at 10 psi then 20 and finally 30. If your compressor is at higher pressures this can be catastrophic.
Thank you
I frighten easily!
"Still not convinced about using an air compressor to fill up a lantern."
I think a wise person will use a manual tire pump with a gage (HF, Walmart, and similar) to pressurize a fuel tank to check for pressure boundary issues. Also fill the tank with water for first pressure test of a tank that might fail.
You have to set the regulator on your compressor at 30 psi or whatever pressure you feel comfortable with and you will be fine
