mgmlvks
The burner parts were in parts lots at the Jahn/Snook auction.  Never knew that until I got home.  Ready to rebuild to original - just searching for a good fount.  Here are some pics - all of them will be posted here - https://www.flickr.com/photos/46064258@N08/albums/72157714871788581
A ton of "patina", but all the parts loosened up without too much trouble, quite likely disassembled or broken down before.
Really odd lamp - apparently made only one year.  Generator is basically a torch light (packed vertical tube) with a match light top (looped brass tip) feeding into two burners.
This burner assembly has been apart based on how easily it disassembled.  The curved air tube and the down tube appear to be "home made" as it is slightly different than the rest seen on the internet.  The tube may even be aluminum!  The down tube hex is asymetrical, and the notch appears to be so also.  And the air tube is "loose" on the downtube with no way to tighten.  Probably does not affect performance  as this is the air moving into the mixing chamber.
Take a looks - tell me what you think!
[50040612923_f854067a41_z]
[50041430932_f428340a26_z]
[50048753841_64d33bcec5_z]
[50049007917_d8b9c794fe_z]
[50049010932_ac59f2a8ee_z]
[50049012337_fa81bdc7db_z]
Francis Bacon
Looks ready for pressurized fuel to me ðŸ‘
Would like to see that one completed
mgmlvks
May put on a CQ fount assuming threads are right!  The looped gen is pretty much "as found" so hoping for good!
Francis Bacon
mgmlvks
CQ don't fit.  Need an adaptor.
Francis Bacon
