keith70
Figured I'd give this another go. Anyone else have an Air-O lantern with and brass frame rest like this?
Gavercronos
That's bizarre on its own, but on a lantern with that filler plug and frame? WOW
Send a message to Terry Marsh. If anyone would know of others in existence it's him.
WillCat
Chautauqua County, New York
Nickel-plated brass, not aluminum. The density should give it away. If that's not enough, try a drop of fairly strong lye solution on part of the inside you can't see. Aluminum will react strongly, nickel-plated brass not at all.
keith70
Thank you! Tried it out, and you are correct. It is brass. Edited post. Still curious if any more folks have one. I thought the frame rests on Air-O's were exclusively steel.
I wish mine was brass.  It's the only original part on mine that I can't bring back to almost new.
lucky you , no rust for you :-)
Good deal!
My very early Air-O QL has a steel collar with almost no plating left. I'll have to fix that some day. Yours is exceptional!
Tigerfans2
Two Air-O's with steel rests
One..transition? With nonferrous rest, swing away door in the frame (like yours) and a circular indentation on the bottom of the fount
Coleman Slant Saver #58
Coleman Quick Lite Crew #8
Coleman Blues 243's #16
smallenginelover
My Air-O also has the steel rest.
BernzOmatic Appreciation Club #072
Earliest iteration of the Air-O-Lantern, with steel rest:
[38983124605_800ec9df54_b]
1916-'17.
keith70
No circular indentation on the bottom of mine.
The earliest version had the round filler cap, correct?
1916-'17.
Willy
Just went out to the garage to check.  Both the Air-O-Lantern and the Air-O-Lamptern  have steel.
Willy
