smallenginelover
I have an AGM 2572 that I got at a thrift store a while back, its by no means perfect but its a good runner. The needle on the cleaning rod is broke off and I am wondering if it would be worth it to try and find a new generator, run it as is, or if I should retire it to the shelf since the founts on these have a habit of cracking. What I want to do with it is make it my main user and take it on vacation with me for a week or two, I'm wondering if that is a good idea or not because of the fount issues. I'm running it with a good 200A cap because the seal in its cap is bad, I already have a new seal on the way. It also is using an old Coleman globe that is similar to another globe I have from the 40s, unfortunately it has a crack in it. Also how do you date these AGMs? Click image for larger version - Name: 20200710_110432 cropped 2ned (wecompress.com).jpg, Views: 41, Size: 176.16 KB Click image for larger version - Name: 20200710_110131 cropped 1st (wecompress.com).jpg, Views: 44, Size: 150.54 KB
BernzOmatic Appreciation Club #072
There are so many of those with stress cracked founts that you should be able to find spare upper parts easily. Post a WTB ad in the classifieds.
I had it in my head a Coleman 220 generator could be made to work? Maybe a pricker rod modification? Might be worth a search on here..I may be thinking of something else...
You got it right Toby.
smallenginelover
I wish a 220 generator would work, here is a spare 220 size generator I have, it is a different length and the cleaning rod has a different end on it. Click image for larger version - Name: 20200710_153727 edited (wecompress.com).jpg, Views: 22, Size: 270.39 KB
smallenginelover
Maybe with some fabri-cobbleing I could make something that would work but I wouldn't know where to start
If the 220 gen will go in far enough to seal up to the air tube I would think it would work. Again I believe you will have to trim or shorten the way the pricker attaches to the eccentric block also
