Vobs
I am working an a 457 and have question about the generator.  Should it have a spring or coil inside?    I think I saw where it does but mine does not.  If it needs one, what can I use as a substitute?
Yes it should have a steel coil, just like a stove generator. In fact you can use a stove gen spring cut to length.
offrink
Not sure but I bet if you find the correct gauge copper wire it should work too. Kind of like what is used for rebuilding a lantern generator.
Ben
ctp51
I broke one and used copper coated tig rod to make one, It works fine.
Tommy P.M. ICCC #1250 With confidence in our armed forces, with the unbounding determination of our people, we will gain the inevitable triumph -- so help us God.
FDR Dec.8th 1941
mcdugal2
A cut down spring from a 413 genny will work...
Phil Rhoades ICCC# 1125
I have some old stove generator springs I liberated from the OCP scrap bucket. PM me and I’ll dig one out for you.
I thought I would give one a try before sending to you. The 413/426 generator spring fits inside the 457 generator tube, but the inside diameter of the spring is too small to allow the HGP needle to pass through. Sorry it won’t work for you.
the earlier stoves didnt have coils but just a set of straight rods , dont remember if it was 6 or 8 of em , had to be careful putting things back together with the rods to keep the cleaning rod centered in the middle . its just something to reduce the fuel volume within the generator and holding heat helping with the vaporizing of the fuel .
