austin65uri
A near mint 400A that was leaking fuel into the pump chamber from a pin hole or tiny crack in the pump tube bottom inside the tank.  I've had some success in fixing this problem with Caswells, so I gave it a try, but the source of the leak was above where I could slosh the epoxy.  So, I salvaged all the useful parts and decided to take a look inside out of curiosity.
Bill.
ICCC#1601
Sorry you couldn’t save the stove but you did cut you loss in half!
Bummer on not being able to save it.
I have a Black 400A and a Brown 400 fount that I will sell if you are interested to get a complete stove again.
austin65uri
Thanks Dan.  I'm sending you a PM.
Bill.
ICCC#1601
If you can now find the source of the pinhole leak, you should be able to solder it.    [sSc_hiding]
austin65uri
Bill.
ICCC#1601
